My 5 years of hard work
kwoo510
  • Replies 14
Awesome! Thanks!  I looked at the rest of the pics in there too.
So the vertical pieces that connect the rack to the tierods are slotted?  You welded a bar across the bottom after they were set?  I'm guessing that is all because the rack had to be lowered for clearance with the oil pan?  Very nice install and appears to be solid!
That sure is a short rack!!
Mike,  the slotted vertical pieces are my test gauge; to test how high my tie rods to be mounted.  The final pieces I have on the truck right now are not slotted.  Yes, the rack had to be lowered to clear the oil pan and the vertical pieces are for correcting the potential bump steer.
