How to install BMW 540 projector lights
  • Replies 2
They don't 'bolt' on.
First off, since they are wayyy deeper then stock, the battery is in the way on the passenger, the horn is in the way on the driver, you have to re-wire to allow the 9006 (easy) and you have to cut the buckets and trim the headlight housings so they can slide into the housing.
