A87 or W53 head
Bugeye
which head would be a better head to put on my l20, right now it has the w53 head, but I have an a87 I pulled off of my parts rig l16 before I sent it to the crusher, im asking because I am getting ready to rebuild my engine and I want the better of the 2 heads (keeping in mind I still have to smog)
Edit, Im a dumb ass, I have the w58 head currently on the truck..put there are now pics of the a87 below
  • Replies 27
Both heads are good ones. Is the A87 open or closed? That would probably be one major deciding factor. I have the nasty ass W58 on my L20B, I have a W53 ready to be rebuilt. IMO, the W53 is a bit rarer than the A87, but on that note, the A87 is more widely recognized. There will be no dispute at a show when someone sees the W53 casting mark, you definitely have a closed chambered head.
I was looking at the a87 looks to be open chamber but im not sure, im gonna snap some pics of it, when it comes to cylinder heads i cant tell the diff from open or closed. looking at the picture of the closed chamber head at http://olddat.com/html/tech/head_ID_2.htm, it looks like that.....what to do what to do
correction, I have the crappy w58 head on my l20,guess my mind saw what I wanted it to see, but here are the pics of the a87 and the crappy w58 thats on the truck
it looks to be a closed chamber from the different photos I have seen, 2 of the chambers have what appears to be a hot spot near the spark plug (#1 and #4) #2 and #3 look like the pic from the620resource.com.....Im an so confused....I hate trying to figure out head work...will this head be a good replacement for my w58, I kept the exhaust manifold from the a87 since i know the w58 is a round port exhaust (see I am doing my homework...somewhat)
thanks guys
thanks guys
The W58 (which I had to do a quadruple take, my mind saw what it wanted to see, too) is the US market smog head. Not real good for performance, but with you having to still smog your truck, might be good at smog time. It has steel liners in the exhaust ports to burn off extra emissions. But, the A87 is available, is closed chamber (see the kidney shape, tell tale indicator), and is much better for performance. Go A87!
looks to me like a semi closed chamber head... :D
See the recessed circle around the "kidney" shape? the "peanut" heads are flat up to the "kidney" shape.
Its still good, and you can actually have that recessed circle area welded up so its a full peanut head... I wouldnt worry about emissions TOO much cause you can always throw on a cat and detune the carb at emissions time...
Of course, the W58 has larger intake ports and valves, and the A87 will require a different exhaust manifold...
I understand this, that is why I kept the exhaust manifold from the a87
only the number 1 and number 4 cylinders have that recessed circle, it looks as if the spark plug got to hot on them...as for emissions, the truck is still running the stock carb (looking for weber and the adaptor to use the stock air cleaner) and it has a brand new cat on it....
on to cam choices, should I run an L20 cam and rockers in it, or is there something else that you guys would recommend?
I think I know what your saying... :D whoops... I was refering to the large circle AROUND the "kidney" shape ;) Or is it just the lighting and the soot making an illusion? clean it up a bit and take some more pics...
after almost 2 hours in the parts washer.....
Peanut chamber head, to be sure. Looks nice. What are you looking for in a cam? I have a good reference:
http://www.webcamshafts.com/pages/automobile/datsun/datsun_l_series_(69-80)_sohc_8v.html
This company not only provided new camshafts, but they also nitride them as well, for durability. Of course, you could get the reground cam, for a lower price.
I have no idea, something to give the truck a little more pep, but still smog legal, im also going to need 2 new cam towers, the first and last one have score marks
Go with the 94a grind. It's supposed to be the same grind offered by Iskendarian Cams (read: Isky) from the '70s and '80s.
MUCH better, looks great! Agreed, definately a peanut head you got there... measure the exhaust valves to see if you got the 1.30 or 1.38 valves... you can keep the smal intake ports for more torque or hog them out for better flow and more HP.
If you need new cam towers, the "right" way to do it is have the tower line bored so they are nice and straight... cam towers can come from just about any L-series head I believe... as far as rockers, valves, spring etc... depends on what you want, ebay... or nissan...
how would that work if there is no bearings in there, the cam just rides in the tower with oil between them?:blink: Im confused:blink: but then again, I just build bottom ends, this is the first top end I am going to build
well I think Hainz said that he just slaps them in and lets the cam "wear in" but the head being made of aluminum, tend to change shape ever so slightly, the towers bolt in... so a change in towers would change the alignment, make sense? If your using ALL brand new towers (do they even make them?) then this would not be "as much" of and issue.
Others may disagree... some may agree... you may be able to get lucky enough that the "new/used" towers line up enough that it wont hurt anything
Here's my W-58 from my '78 when it up and decided to blow the gasket. Definitely semi open. It had the p-nut shape and looked like the top had been milled out to the gasket ring. Did not look cast but had tool marks on it.
http://i138.photobucket.com/albums/q251/datzenmike/motorW-58openL20B78620.jpg[/img]"]motorW-58openL20B78620.jpg
