L series 5 speed starter bolt size?
Eric
Starter on my 260z died so i had to fix that, after unbolting it i found out the top bolt was a wierd piece of bolt, someone tried to make it fit with an angle grinder or something like that. So i wanted to put in a bolt that looked better and fits properly only to find out that the bolt(or the hole it needs to get in to) has a weird size?
It looks like it is a 9mm bolt, 125 thread, is that correct?
  • Replies 5
