I'm BLUE Posted March 11, 2013 Report Share Posted March 11, 2013 Located: Portland,OR All Matching parts ***240mm 6-bolt L-series*** *flywheel *clutch disc *clutch pressure plate *clutch collar and throwout bearing for sale. ***throw-out bearing grows when spun so needs to be replaced ! Price $100 (Will ship by the way) or I might keep it and put to use as well. Thanks and PM is best for fastest response. DTP (rough measurment rounded) 9.5 inches = 241.3mm's Link to comment
I'm BLUE Posted March 13, 2013 Author Report Share Posted March 13, 2013 Pm'd PM returned Link to comment
I'm BLUE Posted March 16, 2013 Author Report Share Posted March 16, 2013 All pm's answered Thankyou. Pictures added to Original post. Link to comment
datzenmike Posted March 16, 2013 Report Share Posted March 16, 2013 With that flywheel you could run a 300zx non-turbo pressure plate. Link to comment
ajen68510 Posted March 16, 2013 Report Share Posted March 16, 2013 With that flywheel you could run a 300zx non-turbo pressure plate. What would the benefit to doing that Mike over a Roadster 2000 clutch ? Link to comment
datzenmike Posted March 16, 2013 Report Share Posted March 16, 2013 Availability of a 200mm flywheel in 5 or 6 bolt. If you have an L20B or any Z series motor this is an option. The 200mm Roadster clamping force is 650KG or 1,430 pounds. The 300zx PP is 600Kg or 1,320 pounds. If it will hold a 300zx turbo it should hold an L20B. Link to comment
