Draker
The forgotten Beige 69 510 build *Pics fixed through page 8*
No.. way.......!  Thanks for taking the time and to cut and past that from the various places datsunmike has posted it.
Sorry, man.  I didn't catch the brofest going on.  Next time try this so you'll be in a better mood:
Share this post
Link to post
Maybe I should use that to lube my L16.. got any other self imposing advice?
Share this post
Link to post
Got all the fuel lines in, plumbed up and ready to fill the tank. If all is good... next up, a brake refresh.
Gonna ditch the old soft lines and get new. I'll be looking for a replacement master. I really hope the brakes aren't as fucked as the fuel lines were.
Share this post
Link to post
Sweet dude that's awesome ..... congrats...
Share this post
Link to post
winning!!!! i should be down this weekend with glass for ya
Share this post
Link to post
Sounds good! I need to get on ordering that seal.
Share this post
Link to post
Round one of parts that came in today.
Share this post
Link to post
Got a trunk thai trunk seal from route 66 restorations in Prineville. i haven't test fit it yet. It was cheap so.. as long as it keeps water out should be fine. If it was in the sun, it feels like it wouldn't last long. Pics when I test fit.
Share this post
Link to post
Its on eBay calling your name...
$T2eC16R,!y8E9s2fjKbbBSJ-VWpLKQ~~60_12.J
Share this post
Link to post
Woah.. ill check it out.
Share this post
Link to post
mine mine mine ..... just kidding ... cuz in my mind its saying (broke broke broke..)
Share this post
Link to post
Put in a little more time today and got this out from the car. It's filthy.. inside and out. Obvious rear main seal leak.
Pressure plate was rusted to the clutch disk.
Clutch disk fused tight to flywheel. Unfortunately it couldn't be saved. It's slightly bent.
Either head gasket leaking oil.. or valve cover. Hope it's just the valve cover cause I know that's leaking for sure.
Rear seal leaking.. got it pulled out and new one is ready to go in.
This is how I communicate with the world.
Looking for a 5 speed.. anyone?
Share this post
Link to post
Getting ready to put a windshield in. Still need to get different seal........
Anyway, there was rust in the 4 corners so I scraped it out and painted it with Zero Rust. I wet sanded away a lot of the grime around the edges.
Next up I'll tape it off and primer around it and them paint over that with some color matched paint in a rattle can.
Share this post
Link to post
Love the original radio, mate!
and those seat! its hard to get good condition original seats here.
Share this post
Link to post
Thanks! I'm digging your car.. lots of rare hard to find parts on it!
Share this post
Link to post
Alright guys. I need some guidance.
I am trying to find out why this engine is running like shit. I had a mis-fire on #3. Compression, spark, fuel good. I am checking out the timing. Here is what it looks like with the crank timed.
Cam is slightly off.. could be from worn timing components? It's not a full tooth off.. measured it and it's about a half a cam tooth off.
Share this post
Link to post
Here is what it looks like when the cam V notch is aligned with the dash mark:
Share this post
Link to post
Issue was old gas.. I am pretty sure. Running good on new gas.
Share this post
Link to post
I'll start updating this thead again.
Swapped out the points distributor. Worked great though. Installed matchbox dizzy. This thing is running really smooth now.
Share this post
Link to post
Some more stuff that happened.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
