White wall tire size for 14's
Djditty
  • Replies 3
Ok bro I'm gonna let you in on the trick to cheap wide white walls......get a thin wire wall tire and take a angle grinder with flapper disc on it...and you can grind the black away to make them wide.....there is a band of white under the black there are edges and it very easy to do...look on you tube at do it yourself white walls......if you get on fb i have pics of mine on my L320 that ii made
