Power steering 510.
69SSS
  • Replies 38
This is the steering box for the S110, its obviously on the wrong side as its all I could find on google, I'll take some pictures of my 200sx and my 510s box to compare,
Not a steering box from an S110... I have one and that's not it. The pitman arm should be on the left. That one is very like the 720/D21 truck box though.
710 (standard steering) and S110 (power)
May have to shorten the column slightly
I'm just fkn with you guys. I did a power steering conversion on my 70 510 with a KA, using parts from different model cars. It is a bolt on deal except the crossmember. I have pictures and all the info of what I did. Car its been running with this set up for about 2yrs no problems and same tires. I also used an S14 steering column but you can stay with the 510 column. So much fun with a small car with power and power steering. Will post pics and all the info when I get a chanse. If you want to try it good if not I don't give a F haha. It won't cost much most parts you can steal from pick and pull just don't tell anyone. Troy hermish drove it and loved it, he said it was the best conversion he had seen.
Power steering: I used 95 240sx rack & pinion I'm pretty sure you can use any year 240sx rack & pinion,complete steering column,center part of the cross member.
I used 86 300zx rack & pinion rods. Don't know what other years are compatible!
87 200sx steering connector this is the part that connects the shaft from the steering column to the rack.
95 subaru impreza tie rod ends. Again I don't know what other years are compatible!
Rack and pinion will fit perfect with this parts combined  together.
this is the cross member
this is how it will look mounted
this is using s14 240sx steering column
mounting bracket for S14 steering column all by hand thats why it's a little crooked
cut the wings off S14 mounting bracket
weld wings from stock steering column to s14 column. you need an extra bracket at the lower end but I don't have a picture of it.
I used the S14 column because I wanted to have the tilt and be able to adjust my wheel.
welded flanges.
and this is the bracket at the end of the column. instead of using the s14 column boot I used a shifter boot from the S14.
my good friend Pedro did the final touch. DON'T FORGET TO VOTE FOR HIM!
S14 cluster
this is the stock S14 rod and 300z rod.
you have to extend the motor mounts by 3/4"
you can see in this picture the cross member was moved 1" back and 1/2" down to clear oil pan. square metal plates where use to extend the center piece.  Raising the brackets gives you just enough to fit the rack.
the rack with 300z rods and stock rod ends
subaru impress tie rod ends.
engine mounted everything clears.
Very simple setup. didn't cost that much, and if you weld you save even mo $.
  • 3 months later...
  • 2 months later...
