Bullet_side Posted May 2, 2013 Author Report Share Posted May 2, 2013 TY I have a bit of experience with glass. Its actually easy to work with, its all about the preperation. Thanks for lookin. Quote Link to comment
BigBlack620 Posted May 3, 2013 Report Share Posted May 3, 2013 Nice work man! It's coming along perfect ... I'm starting on my 74' tomorrow or maybe even today ... I want to start by pulling the bed, cleaning the back frame for paint, then bed, then gut the cab, pull the cab, recondition the front of the frame, then engine ... You've done enough builds where I can ask you if that's a good order or not Quote Link to comment
Bullet_side Posted May 4, 2013 Author Report Share Posted May 4, 2013 Yea that would work fine. I started with gutting the interior and glassed the floors. Re undercoated or painted the front clip including the vent area(all after using rust doctor on all rusty spots) . Reworked the fenders, hood, vent, roof, sides and kick panels. Painted the inside and primered the outside. Now removed bed working the rust etc. back of the cab and have painted rust doctor on the frame (well most of it). Also took four seats apart and made two good ones (except the skins which I will just use a cover for now) including spring repair etc.. Working on re covering the door skins (had to build a door panel because the drivers panel was in pieces), side kick and back panels with black covering. Need to buy new headliner, working on glass etc. etc. and so on. Always something to do. I have plans for the lights and stuff but all that is after the body, interior and then engine. I will be rebuilding the L20B SS headers offenhouser intake weber 32/36 need a good head and cam first before rebuild to know which pistons to buy etc. Need a 5 speed. Well I probly already said to much for one post. Let me know how your doin sounds like you excited to start. BTW I am originally from Whittier CA and had friends in Corona. Have fun Quote Link to comment
Bullet_side Posted May 6, 2013 Author Report Share Posted May 6, 2013 Look ..... No more hooks!! Painted the frame under the bed with rust doctor and then paint. Quote Link to comment
Bullet_side Posted May 7, 2013 Author Report Share Posted May 7, 2013 Sandblasted all the seams. Took forever. Nest pic will show that after this I brushed and lightly blew (with canned air) rust doctor into the seams several times and then wiped off the excess so that there was a layer of rust doctor to protect the seams and pit holes. Quote Link to comment
Bullet_side Posted May 7, 2013 Author Report Share Posted May 7, 2013 Removed the paint. You can see all of the rust I need to attend to (dark areas) on both sides. Quote Link to comment
Bullet_side Posted May 20, 2013 Author Report Share Posted May 20, 2013 Well I had a few issues come up and couldn't work on the truck for a couple weeks, but I'm back now. I had an issue trying to get the spot weld areas (as well as the rust areas I had to fix) on the top/side area of the bed smooth. I decided to make a tool that would be as long as a sheet of sand paper and match the angles of the bed. So I found that the tailgate was good and decided to make a mold of the area and use this mold to sand the bed sides so they were mostly all the same. Heres the pictures of before and after and how well the tool fit. Enjoy. I hope it looks good after paint! Quote Link to comment
Bullet_side Posted May 25, 2013 Author Report Share Posted May 25, 2013 Sealed up the seams with 3M seam sealer. I shouldn't have to worry about rust in the seams anymore!! Quote Link to comment
Dirttrack510 Posted May 25, 2013 Report Share Posted May 25, 2013 Nice little build page. :) I'd of kept the bed hooks though :( I always thought they were cool and very handy. :) Quote Link to comment
Bullet_side Posted May 26, 2013 Author Report Share Posted May 26, 2013 Ive owned several 620's and never took them off b4. Something different plus it kinda looks cool without. Thanks for lookin. Quote Link to comment
Bullet_side Posted June 25, 2013 Author Report Share Posted June 25, 2013 Bed sides and tailgate finished (as good as they are going to get). Added visor and airdam for some personality. Interior below. 1 Quote Link to comment
Bullet_side Posted June 25, 2013 Author Report Share Posted June 25, 2013 Time to vinyl the interior panels. All original except drivers door panel, had to make it because it was in pieces. All vinyled up! Now to pull the engine and put in the other L20B (it doesnt smoke and runs very good). Then maybe send it to paint. Quote Link to comment
Eagle_Adam Posted June 25, 2013 Report Share Posted June 25, 2013 deff wanna see that interior installed!!!!!! Quote Link to comment
Bullet_side Posted June 25, 2013 Author Report Share Posted June 25, 2013 Well here's a pic of the back panels in (the only ones in until after carpet and paint). Quote Link to comment
Bullet_side Posted July 21, 2013 Author Report Share Posted July 21, 2013 Ok engine change out is complete. Runs great! Now final touches before paint! I gotta note, no matter how hard you try, you still get grease everywhere. I should have covered the fenders but I got into my work and by the time I remembered, it was too late. Quote Link to comment
Bullet_side Posted August 26, 2013 Author Report Share Posted August 26, 2013 Had to fix brakes. Replaced front shoes ( the pad on one shoe was completely broken free from the base ) and adjusted all brakes. All brake adjusters were frozen, but three of them took some serious pounding to get out. Had to sand off the rust throughout and grease everything up. At least there not lockin up now. Good to go! Quote Link to comment
Bullet_side Posted September 5, 2013 Author Report Share Posted September 5, 2013 Painted and clear coated grill and strip attached to hood. Fixed cleaned and installed grill chrome, and installed old school rubber on the airdam. One step at a time. Quote Link to comment
Bullet_side Posted September 21, 2013 Author Report Share Posted September 21, 2013 New headliner - tinted windows - all new rubber on and around doors, hood, windows etc - assembled interior with recovered side, back and kick panels (and everything else) - added 5 panel mirror - new carpet etc for interior. 1 Quote Link to comment
Bullet_side Posted September 21, 2013 Author Report Share Posted September 21, 2013 New paint - installed windows, mirrors, airdam, visor, lights, grill, new antenna, etc. 3 Quote Link to comment
cruznude Posted September 21, 2013 Report Share Posted September 21, 2013 Dude, your truck looks FN awesome!! I got to give you credit for all that hard work you've done. Good job!!! Where do you buy that rust doctor and that 3m seam sealer? Did you fill in all the spot weld marks on the top of the bed? Let me know about that I'm lookin at doing the same to the seams w/o welding if I can help it. Thanks Quote Link to comment
Bullet_side Posted September 21, 2013 Author Report Share Posted September 21, 2013 The rust doctor I ordered on the internet. I was told it was the best so I went with it. There are other brands that do the same thing from Wesco which is a place to buy auto paint and body supplies. The 3M sealer I got from NAPA You dont need the two part only single part will do (two part is for bonding two sheets together tou only need to seal the gaps). The top spot welds I used "two part" spot putty from napa it costs a bit more but worth it. It is easier to sand. Also you can ask me anytime but I asked alot from Ratsun.net of facebook. Poeple are very helpful, thats where I learned alot of what I did. Good luck 1 Quote Link to comment
heretic Posted September 23, 2013 Report Share Posted September 23, 2013 GREAT job & good looking truck man.!!! what carpet did you use? Quote Link to comment
Bullet_side Posted September 23, 2013 Author Report Share Posted September 23, 2013 Thanks I actually used two carpets kits from JC whiney because the regular cab only fits in front of the seats but not the back. This one http://www.jcwhitney.com/custom-tailored-nylon-cut-pile-carpeting/p2007246.jcwx?filterid=d50465y1977g2j1 I also called them and told them by the roll for the back and cut it out. I think it was this one but not sure they made sure it was the same material. http://www.jcwhitney.com/replacement-carpet-by-the-roll/p2017637.jcwx?filterid=d50465y1977g2u0j1 Good luck Quote Link to comment
heretic Posted September 24, 2013 Report Share Posted September 24, 2013 right on thanks.!! are you happy with the fit of the front section? Quote Link to comment
]2eDeYe Posted September 24, 2013 Report Share Posted September 24, 2013 Good to meet you at the Carls Jr meet. Truck looks great, still smelled of fresh paint :D 1 Quote Link to comment
