Yeti Posted March 6, 2013 Report Share Posted March 6, 2013 In case anyone needs any parts, I've got a full set of power window/door lock components including PDL timers x2 and harness. PDL actuators x2, Door swiitch passenger and driver, and assenger and Driver side power window assembly including motors. Quote Link to comment
Laecaon Posted March 6, 2013 Report Share Posted March 6, 2013 Why not just wire the windows up without the harness? Its super easy. Ill make you a diagram... Electrically speaking, you just need the motors and switches. Then a relay. There really isnt any magic. Quote Link to comment
djflizo69 Posted March 6, 2013 Report Share Posted March 6, 2013 In case anyone needs any parts, I've got a full set of power window/door lock components including PDL timers x2 and harness. PDL actuators x2, Door swiitch passenger and driver, and assenger and Driver side power window assembly including motors. Hey yeti, do you have the complete doors? Quote Link to comment
djflizo69 Posted March 6, 2013 Report Share Posted March 6, 2013 Why not just wire the windows up without the harness? Its super easy. Ill make you a diagram... Electrically speaking, you just need the motors and switches. Then a relay. There really isnt any magic. Laecaon, that would be great!! I'm sure there is quite a bit of people here wanting to know how to wire them up to there rigs.Thanks for thinking of that. Quote Link to comment
Sealik Posted March 6, 2013 Report Share Posted March 6, 2013 Laecaon, that would be great!! I'm sure there is quite a bit of people here wanting to know how to wire them up to there rigs.Thanks for thinking of that. I think you would need the 720 wiring diagram....????...there is also PL to hook up Quote Link to comment
Laecaon Posted March 6, 2013 Report Share Posted March 6, 2013 I think you would need the 720 wiring diagram....????...there is also PL to hook up Eh, its just 2 switches on the left, and 1 on the right. Im guessing the switches have 5 wires to them (most common type). Ill consult a wiring diagram PLs are easy too, but require the use of 2 relays for aftermarket install. Im currently wiring up PW & PL in my 510... which never had those as an option... Quote Link to comment
DREWSDIME Posted March 6, 2013 Author Report Share Posted March 6, 2013 That would be awesome Laecaon! Yes only 5 wires maybe only 4 coming off plug from motor and switches. Is it still possible to have the driver side roll down the passenger? Quote Link to comment
Laecaon Posted March 6, 2013 Report Share Posted March 6, 2013 That would be awesome Laecaon! Yes only 5 wires maybe only 4 coming off plug from motor and switches. Is it still possible to have the driver side roll down the passenger? Arent there 2 window switches on the drivers door? and then 1 on the passenger? Quote Link to comment
Yeti Posted March 6, 2013 Report Share Posted March 6, 2013 Hey yeti, do you have the complete doors? No, I no longer have the complete doors. Quote Link to comment
DREWSDIME Posted March 6, 2013 Author Report Share Posted March 6, 2013 Arent there 2 window switches on the drivers door? and then 1 on the passenger? Yes, like I said Im not too good with wiring. I would gladly send you something in return for helping with wiring them up Quote Link to comment
Laecaon Posted March 6, 2013 Report Share Posted March 6, 2013 Ok, can whoever has the switch(es), take a picture of the wires coming out of it? I have looked at the 280zx diagram, and a D21, and decided that the factory diagrams are overly detailed, or for some silly reason Nissan made their switches over complicated. Basically either the switch will have 5 wires coming out, or 6. Quote Link to comment
elmerfudpucker Posted March 6, 2013 Report Share Posted March 6, 2013 Bro! could you show us how you did it? Maybe a wright up? I;m sure a lot of people would really appreciate your efforts!!! Thanks!!!!!! relay pack x 2 http://www.the12volt.com/installbay/uploads/FBB_actuatorrevpol.gif switch http://www.the12volt.com/installbay/uploads/CC1_for_windows.gif Quote Link to comment
DREWSDIME Posted March 7, 2013 Author Report Share Posted March 7, 2013 Here is a pic of the plugs, 6 wires like you thought Quote Link to comment
djflizo69 Posted March 12, 2013 Report Share Posted March 12, 2013 TTT!!!!!!!!! Laecaon, Any word on that write up? We would really like to see how you would do it. Thanks!! Quote Link to comment
DREWSDIME Posted March 12, 2013 Author Report Share Posted March 12, 2013 Me too! Quote Link to comment
Laecaon Posted March 12, 2013 Report Share Posted March 12, 2013 Sorry guys, I just need to sit down and write it out. Im thinking tomorrow... Quote Link to comment
DREWSDIME Posted March 12, 2013 Author Report Share Posted March 12, 2013 Sorry guys, I just need to sit down and write it out. Im thinking tomorrow... No hurry whenever you get a chance it is just for future reference, I have the doors just dont know when Im doing the swap probably after my 510 gets back from KA swap :thumbup: Quote Link to comment
goichi1 Posted March 27, 2013 Report Share Posted March 27, 2013 I've recently found a set of Power window ST doors and wanted to install them on my 720 standard, I also removed the entire chassis harness from the donor truck, it was a real bitch to get it all out, I don't recall there being a box or relay in the back near the fold down seat, maybe I missed it?? I thought the dome light delay box was back there?? So, to remove the entire harness you basically have to remove the entire dash, heater, a/c, steering column, pedal bax assy, just about everything that's mounted to the firewall or cut it. The pedal box is the most difficult so I cut that bracket once I figured I couldn't get it out. I plan to remove the p/w and p/l wiring and then install that in my truck (option 1, easier), or just swap the entire harness as one piece (option 2, the hardest). The doors are the same size, glass and all, but the inner metal panel is punched or pressed different to accomadate the big motor assy in the door. I really wanted to keep my original doors but this would be too much work cutting and welding the inner panels, so I'll swap the entire door. This is about the last option for my 720, I think I have all the others covered and really want to get this done soon. I'm tired of moving the spare doors around my garage. I'll try to take some pics of the process. Quote Link to comment
djflizo69 Posted June 26, 2013 Report Share Posted June 26, 2013 TTT!!!!!!!!!! Anyone done this yet? I'm Ready to put these doors in!! Quote Link to comment
elmerfudpucker Posted June 28, 2013 Report Share Posted June 28, 2013 I did, wire 2 relay packs as shown in the first link in the quote, the switches are on the second link. Use an auto resetting breaker on the main 12v in, they are in the fuse box of most cars with power windows or seats. the packs can go in the door kicks or in the dash, run two wires to the window motor and your golden. relay pack x 2 http://www.the12volt.com/installbay/uploads/FBB_actuatorrevpol.gif switch http://www.the12volt.com/installbay/uploads/CC1_for_windows.gif The wiring for the door and relays are pretty much the same in my power lock how-to that you can find here: http://community.ratsun.net/topic/21642-after-market-power-locks/ Quote Link to comment
