Sierra Posted March 2, 2013 Report Share Posted March 2, 2013 So the hood frame and the hood it self are completely detach. The stuff that was holding it together is all burnout or nonexistent. Any suggestions on how to attach the metal frame and the sheet that makes the hood. Quote Link to comment
Dawa Posted March 2, 2013 Report Share Posted March 2, 2013 silicone sealer, the kind they use for windows. GE 2 i believe. this is what some wheel companies use to seal their 2/3 piece wheels, so i would think it would work? that is, unless someone can come up with a better/more correct sealer/adhesive 1 Quote Link to comment
Dguy210 Posted March 2, 2013 Report Share Posted March 2, 2013 silicone sealer, the kind they use for windows. GE 2 i believe. this is what some wheel companies use to seal their 2/3 piece wheels, so i would think it would work? that is, unless someone can come up with a better/more correct sealer/adhesive This what I used when I fixed mine...about 12-13 years ago. Still holding strong. There were glued from the factory with something similar I believe. Quote Link to comment
mcmlxxxv Posted March 3, 2013 Report Share Posted March 3, 2013 http://3mcollision.com/3m-flexible-foam-08463.html this might be what you're looking for ;) 1 Quote Link to comment
