Farmer Posted July 9, 2008 Report Share Posted July 9, 2008 Trying to figure out how to disasymble it. Have it off the truck already, got the nuts off but cant figure out how to get the bushings apart. Reading the manual and its greek to me. Helps needed Larry Quote Link to comment
yello620 Posted July 10, 2008 Report Share Posted July 10, 2008 upper link spindle? Upper control arm shaft? Are you just trying to replace the bushings? No new metal outer sleeves on the new bushings is there? Jason Quote Link to comment
Farmer Posted July 10, 2008 Author Report Share Posted July 10, 2008 Hanyes calls it upper link spindle. What the upper control arm connects to. I just got the rubber bushings from Rockauto. I see there are some metal sleeves and stuff too. I just wanted to take it apart so I can get everthing hot tanked. The rubber will be destroyed in the tank. They are still in good shape, so I many spend the many hours cleaning the 30yr old grease off. Larry Quote Link to comment
yello620 Posted July 10, 2008 Report Share Posted July 10, 2008 Hanyes calls it upper link spindle. What the upper control arm connects to. I just got the rubber bushings from Rockauto. I see there are some metal sleeves and stuff too. I just wanted to take it apart so I can get everthing hot tanked. The rubber will be destroyed in the tank. They are still in good shape, so I many spend the many hours cleaning the 30yr old grease off. Larry So let the hot tank destroy them, then oyu wont have to worry about how to get them out, just have to get the new ones in. Jason Quote Link to comment
Farmer Posted July 10, 2008 Author Report Share Posted July 10, 2008 So let the hot tank destroy them, then oyu wont have to worry about how to get them out, just have to get the new ones in. Jason Never thought of that. Larry Quote Link to comment
