Master-O-Turbonics Posted February 23, 2013 Report Share Posted February 23, 2013 Here is an EFI setup off of a Z20. This is NOT complete ready to run kit! Will need some work and understanding of EFI systems! Located in Atlanta, Ga. $100 OBO + shipping. complete take-off intake manifold with injectors and fuel rail. Z22 ECU and a cut wiring harness. The guy I got it from was going to use megasquirt so he cut up the harness and took out everything he wasn't going to use. included is the MPG plenum and throttle body(on the intake manifold), a small throttle body, and a large throttle body with its upper plenum. Only the large throttle body has a TPS. Link to comment
