Kyle84 Posted March 1, 2013 Author Report Share Posted March 1, 2013 Its already dropped and banging the bump stops! bahahaha. i so would though. maybe i can cut some off the bump stops and lower it some more... On second thought... the step dad knows how to weld! :O Wanyeo.... How exactly did you make those? Don't they tuck the wheel in more at the bottom since the arm is put slightly on top of the other? I can get a set from the JY to test on... did you do top and bottom or just bottom? :) Quote Link to comment
wayno Posted March 1, 2013 Report Share Posted March 1, 2013 I overlapped this set about a half an inch, the reason for this is that when you lower the vehicle, the upper control arm balljoint starts to move towards the engine, and how the UCA mount is made, you cannot move the mount out(away) from the engine, so I make the lower arm shorter so I have alignment room. The ones I am using on the 520 are 1 1/2" overlapped on each side for two reasons, to narrow the track so the wheels don't rub on the fenders, and because the upper UCA is at such an angle. See how angled the UCA is, this is bottomed out on the bump stop, and I have about an 1/8" left on the shock before bottomed out. In the photos above and below, I have negative wheel camber. I really cannot go any lower with the suspension without modifying the tierod ends, maybe I could bend them. Quote Link to comment
wayno Posted March 1, 2013 Report Share Posted March 1, 2013 Its already dropped and banging the bump stops! bahahaha. i so would though. maybe i can cut some off the bump stops and lower it some more... On second thought... the step dad knows how to weld! :o Wanyeo.... How exactly did you make those? Don't they tuck the wheel in more at the bottom since the arm is put slightly on top of the other? I can get a set from the JY to test on... did you do top and bottom or just bottom? :) You should look at what I did first hand before you try it yourself, that way you can make your own decision on how you want to make yours, if your just going for a 2 inch drop, you don't really need to shorten the arm. Quote Link to comment
Kyle84 Posted March 1, 2013 Author Report Share Posted March 1, 2013 Yeah. I may just go after drop spindles. Does anyone have any idea what wheels these are or where they came from? Quote Link to comment
Kingman Posted March 1, 2013 Report Share Posted March 1, 2013 Dude, your control arms are going the wrong way! :rofl: Quote Link to comment
wayno Posted March 1, 2013 Report Share Posted March 1, 2013 Dude, your control arms are going the wrong way! :rofl: Are you talking about the fact that they are on upside down? They are on upside down for a reason, they do not bind this way, and they are also reversed, the right is on the left and the left is on the right. I am basically bottomed out in this photo above(sitting on bump stops), as the torsion bars are not tight at this time, the bolts were removed so I could check for travel issues and to make sure the shock did not bottom out. To go any lower, I will have to raise the shock tower, and replace this cross member with one that doesn't hang down below the frame rails, I am just over 2 inches off the ground. 1 Quote Link to comment
Kyle84 Posted March 2, 2013 Author Report Share Posted March 2, 2013 Removed my drivers side bump stop I'm the rear. (Pass side was already gone) today. And it made it a little lower. Hahahah. Quote Link to comment
Kyle84 Posted March 2, 2013 Author Report Share Posted March 2, 2013 I think i broke it..... :crying: :unsure: Quote Link to comment
wayno Posted March 2, 2013 Report Share Posted March 2, 2013 I think i broke it..... :crying: :unsure: So what did you break? Suspension? Engine? Quote Link to comment
DeviousPsycho620 Posted March 2, 2013 Report Share Posted March 2, 2013 The whole truck? Quote Link to comment
Kyle84 Posted March 2, 2013 Author Report Share Posted March 2, 2013 Ive got "torque steer" now. i think my new ubolts are loose. im about to go check them. Quote Link to comment
Mr.Dean_Yates Posted March 2, 2013 Report Share Posted March 2, 2013 Think 4" would be too much for the rear of my truck? :D My springs are approx 2.5" wide, so these WILL fit. :) :hyper: http://thesuspensionsource.mybigcommerce.com/4-lowering-blocks-w-u-bolts-hardware/ 4" will put you axle to frame. Quote Link to comment
Mr.Dean_Yates Posted March 2, 2013 Report Share Posted March 2, 2013 I overlapped this set about a half an inch, the reason for this is that when you lower the vehicle, the upper control arm balljoint starts to move towards the engine, and how the UCA mount is made, you cannot move the mount out(away) from the engine, so I make the lower arm shorter so I have alignment room. [img=http://i937.photobucket.com/albums/ad212/waynosworld/720%20drop%20LCA/DSCN1525.jpg] [img=http://i937.photobucket.com/albums/ad212/waynosworld/720%20drop%20LCA/DSCN1526.jpg] The ones I am using on the 520 are 1 1/2" overlapped on each side for two reasons, to narrow the track so the wheels don't rub on the fenders, and because the upper UCA is at such an angle. [img=http://i937.photobucket.com/albums/ad212/waynosworld/720%20drop%20LCA/DSCN0159.jpg] See how angled the UCA is, this is bottomed out on the bump stop, and I have about an 1/8" left on the shock before bottomed out. [img=http://i937.photobucket.com/albums/ad212/waynosworld/1966%20datsun%20520/DSCN0345.jpg] In the photos above and below, I have negative wheel camber. [img=http://i937.photobucket.com/albums/ad212/waynosworld/1966%20datsun%20520/DSCN0348.jpg] [img=http://i937.photobucket.com/albums/ad212/waynosworld/1966%20datsun%20520/DSCN0360.jpg] [img=http://i937.photobucket.com/albums/ad212/waynosworld/1966%20datsun%20520/DSCN0349.jpg] I really cannot go any lower with the suspension without modifying the tierod ends, maybe I could bend them. [img=http://i937.photobucket.com/albums/ad212/waynosworld/1966%20datsun%20520/DSCN0356.jpg] Just cut a channel out it'll be safer and your steering will actually work properly Quote Link to comment
Kyle84 Posted March 2, 2013 Author Report Share Posted March 2, 2013 Yeo they were loose as hell! Lol... Quote Link to comment
Kyle84 Posted March 2, 2013 Author Report Share Posted March 2, 2013 there was about a 1/8" gap between the block and the axle plate at the front side of the axle. on both sides. O.o how in the hell that happened i have no clue. but yeah. Installed my tach and clock. no to find a center console or cut holes in mine to install the factory oil and volt gauges. Quote Link to comment
DeviousPsycho620 Posted March 2, 2013 Report Share Posted March 2, 2013 Ebay has them starting at about $30. Quote Link to comment
Kyle84 Posted March 2, 2013 Author Report Share Posted March 2, 2013 I'm starting to wonder if this thread should be moved to the project section... lol. Ill let the mods decide that. I should be able to find one at the junkyard, if not ill just cut holes in the datsun plate on mine. :) Quote Link to comment
DeviousPsycho620 Posted March 2, 2013 Report Share Posted March 2, 2013 The make a plate for the console to house them. Don't go cutting holes in shit. Those plates are hard to find. save it and make a plate out of some plexi or something. Quote Link to comment
Kyle84 Posted March 2, 2013 Author Report Share Posted March 2, 2013 afaik the plate is connected to the center console? And there are little plastic tabs holding the "Datsun" in. Well not even really tabs. But.. anyway. lol ill look around for the plate you are taking about to house the gauges. lol. Quote Link to comment
DeviousPsycho620 Posted March 2, 2013 Report Share Posted March 2, 2013 http://www.ebay.com/itm/Datsun-nissan-720-80-87-shifter-trim-console-gauges-L20B-blue-/321080749384 Looks like this. Good luck. Quote Link to comment
Kyle84 Posted March 2, 2013 Author Report Share Posted March 2, 2013 That looks pretty cool. Quote Link to comment
DeviousPsycho620 Posted March 2, 2013 Report Share Posted March 2, 2013 http://www.infamousnissan.com/forum/showthread.php?p=326815 This guy might still have it for sale. Worth a shot. Your color too. Quote Link to comment
Kyle84 Posted March 3, 2013 Author Report Share Posted March 3, 2013 I sent him an email. I'm wondering if steve can't get the one from the jy he got my gauges from for some reason... Quote Link to comment
ryanw1 Posted March 3, 2013 Report Share Posted March 3, 2013 I sent him an email. I'm wondering if steve can't get the one from the jy he got my gauges from for some reason... i pulled one outta a junkyard for 10 bucks idk if thats been decussed I didnt read much Quote Link to comment
