mklotz70 Posted October 14, 2014 Report Share Posted October 14, 2014 It looks great, but it's gonna be a bit tall for some applications. :) 1 Quote Link to comment
JoeCool Posted October 25, 2014 Report Share Posted October 25, 2014 It is a little tall for my application. I realized today the wing nut and bolt scraping the bottom of the hood is what the squeaking noise is I have been hearing when it is idling. 1 Quote Link to comment
wayno Posted October 25, 2014 Report Share Posted October 25, 2014 Trim the bolt sticking up a little, and use a nut instead of that wing nut if you have to. 1 Quote Link to comment
schroedz Posted September 11, 2018 Report Share Posted September 11, 2018 On 2/22/2013 at 11:20 PM, dat521gatherer said: Go old school and find a original aluminum screw down air cleaner housing. What are the dimensions and where can you find just the air filter part? 4x6? Thanks 1 Quote Link to comment
seattle smitty Posted September 14, 2018 Report Share Posted September 14, 2018 (edited) FWIW, yet another supplier of those little rectangular chromed boxes for the 32/36 DCAG/DCEG is Borg Warner of Australia, selling them here under the name Warneford. They don't put any I.D. on their little chromed stampings, so you without the box it came in you won't know if it's one of theirs. I assume it's like many similar ones in having the baseplate screw down on the Weber flange, while those clips hold the rest of it together. My 2 cents, those simple filters are okay for when you are in the process of adapting a Weber to a Datsun or whatever, but that ultimately none of those open filters is nearly as good as a closed factory type air cleaner rigged to draw heated air during warm-up and outside air once warmed up. And you can get a K&N filter element, the best there is, and cleanable. Recently Fram has brought out their copy of a K&N, so that might be as good. I like the adaptions of stock Datsun air cleaners that I see in the photos here. I did that for another car ('86 Dodge Colt Vista), and it's always interesting to see how other guys do things. I'm in the process of making an adapter to put a Weber on a Z-22. Would've been done before now but I managed to screw part of it up on the first attempt; was making the two-part adapter out of phenolic, and stupidly drilled out the mounting holes too big to thread for studs. Well, I wasn't fully sold on this anyway, so I'm re-making this part (upper half of the adapter) from aluminum. In any case, the height of the Weber, base to flange, luckily is a good bit lower than the same dimension for the original Hitachi, so there is s bit of space for us to make adapters that don't put the Weber way up in the air. Down the road, if I have nothing better to do, I think I can fabricate a somewhat better intake manifold than the factory Z-22 manifold, but of course once you have a particular set-up working, you tend to forget about it and go on to other projects . . . okay, YOU don't, but I do. Edited September 14, 2018 by seattle smitty Quote Link to comment
