91b22 Posted February 13, 2013 Report Share Posted February 13, 2013 Noticed on my datsun 620, the longer drive shaft has a small dent, ill get a pic of it tomorrow, should i be worried about this? also, when you take the rear yoke off the front shaft to replace the carrier bearing, do the front yoke on the slip yoke part, and the yoke the bolts up to the rear of the front drive shaft need to be on the same "plane"? thanks in advance for your help. Quote Link to comment
datzenmike Posted February 13, 2013 Report Share Posted February 13, 2013 I would mark the position of the driveshafts/U joints with a scratch so they can be put back together as they were. Carrier bearings rarely go bad. If vibration, it's likely a U joint or the rubber doughnut around the carrier bearing has rotted away. Without the rubber support the driveshaft becomes unstable and flops around. This thing... Quote Link to comment
Dawa Posted February 14, 2013 Report Share Posted February 14, 2013 small dent, nah i wouldnt worry about it. i have a small dent too and my DS is fine. Quote Link to comment
datzenmike Posted February 14, 2013 Report Share Posted February 14, 2013 Small dent is fine but can't be bent. If bent, the weigh will be off center and will wobblw/vibrate. Quote Link to comment
hvyd Posted February 15, 2013 Report Share Posted February 15, 2013 What would be awesome is if some one could come up with an aftermarket carrier. The stock replacements rubber goes bad so quickly especially if you do a good amount of hard driving. Quote Link to comment
Pacific coast Datsun Posted February 16, 2013 Report Share Posted February 16, 2013 ^^^^im working on something along those lines. Ill text you a pic soon... Quote Link to comment
