Possible 510 Setup?
slowmomiata
i found this on partsgeek.com
they are 100.25 free shipping monroe struts with
built in spring and spring mounts, comes with all
the rubber and nuts for mounting.
the problem is they say they are for station wagons
but i think this is the solution for 510 sedan/2dr
rear coilovers that are prebuilt! idk the whole
overall length on the setup but if you are looking
for a lowering setup you should be able to cut the
spring a little or even go to amazon.com and search
godspeed civic lowering springs and buy a set of
sleeves and use the springs for an insane drop
while already having the spring mounts!
has anyone ever bought these before seen them?
any input on this monroe setup?
i may email partsgeek and see if they can give me
an overall length of the combo
i have a make shift ghetto setup right now that works
great on my car, if i am feeling giddy i might order
these and see how it may work out for future info
and guidance for a new diy coilover setup
  • Replies 7
Those are more like add a leafs. Designed for carrying heavier loads, they have progressive rate springs.
I dont think these are up to the task, probably not a large enough spring rate.
Just build yourself some coilovers and be done with it.
i think these are the ones that came with my 510. it had these and still and the stock springs in. Dont expect to go much low with these. i took out the stock springs and put ebay "coilover springs" slammed the car and blew the shocks. Now i have some Qa1 coilovers $500, cheaper that troy ermich and techno toy tunning coilovers, and they ride amazing with 300lb springs.
i already built some rear coilovers but i was just wondering
if these would work, guess not haha my coilovers are hands
down the cheapest ratsun setup, 35 dollar amazon springs,
stock replacement struts, and gate latches lol
may be a little ghetto but the ride is actually pretty
nice, i was just wondering if those would work
