240mm Flywheel+Clutch set
Portland,OR
I have a 240mm clutch pressure plate , disc , and flywheel set.
Comes with correct clutch collar , a good throwout bearing and correct clutch fork ( as seen in pictures )
Disc needs to be replaced , and flywheel should be turned.
Slave cylinder and Master cylinder is there if need be.
*** This came off a running and driving L28e as a complete set on Friday (01/25/13) ***
$75
Prefer local pickup.
pm is best contact.
  • Replies 3
This topic is now closed to further replies.
