ianlink Posted January 25, 2013 Report Posted January 25, 2013 started to get some vibrations in my driveshaft, turns out the transmission is torn up on the housing around the spline where the driveshaft connects in, anybody know where i can find a transmission, or any suggestions as to what i should do, i want to keep this truck running as it is in great shape and is a fun little truck, thanks.... Quote
datzenmike Posted January 25, 2013 Report Posted January 25, 2013 The '68 and up J13 powered 520 4 speed has the same tailstock as the 510 4 speed. The earlier '65-67 was different in some way but I'm not sure what. The driveshafts were the same for all J13 4 speeds so that's the same. Might be worth getting a 510 4 speed and try swapping the tailstock. Well..... if you can't find another 520 4 speed that is...... Quote
MikeRL411 Posted January 25, 2013 Report Posted January 25, 2013 If all else fails. bore out and sleeve the tail. Quote
ianlink Posted January 26, 2013 Author Report Posted January 26, 2013 yeah i just dont know if i want to invest the money in the stock motor and trans if i intend on swapping the motor out later on, what kind of swaps are easier to do on the year of truck, i have big plans for it, just need some direction. Quote
ianlink Posted January 26, 2013 Author Report Posted January 26, 2013 yeah finding another 520 4 speed might be difficult, if anybody finds any links to one let me know......much appreciated. Quote
datsunpolisher Posted February 21, 2013 Report Posted February 21, 2013 That 67 520 ive been pulling parts off still has the tranny in it. Im in fresno area. Where are you at. Quote
zed1 Posted February 21, 2013 Report Posted February 21, 2013 datsunpolisher, I am looking for the following:1) Transmission Rubber Boot (photo attached) Item 30 athttp://www.carpartsmanual.com/datsun520/Datsun520521Index/PowerTrain/TransmissionCase/ToSep65/tabid/1455/Default.aspxThe boot for the transmission supplied with the J Series motor is different from the L Series supplied transmission.2) COVER-DUST Item 22 athttp://www.carpartsmanual.com/datsun520/Datsun520521Index/PowerTrain/Clutch/J13ToSep66/tabid/1451/Default.aspxThanks,Keith Quote
TENDRIL Posted February 21, 2013 Report Posted February 21, 2013 Damn I had one really clean on the inside no play anywhere.... I threw it away tho you could of had it for free Quote
