mtngoat Posted January 25, 2013 Report Share Posted January 25, 2013 I can never get it straight. I'm not sure i've ever gotten it like it's supposed to be. Izzat one with the tab supposed to face front or back? Top or bottom? What about the other one? it never looks right to me. Someone have an EZ reference guide for a stupidhead? Quote Link to comment
ggzilla Posted January 26, 2013 Report Share Posted January 26, 2013 The order is: * cylinder * Lock Plate A (square-cut shim, open end points away from handbrake pivot) * Lock Plate B (round-ended shim) * Lock Plate C (angle-cut shim) * Lock Plate D (shim with Tab, tab faces towards the cylinder) * rubber dust cover Plates B,C,D have the open end toward the handbrake pivot Quote Link to comment
mtngoat Posted January 27, 2013 Author Report Share Posted January 27, 2013 Hey thanks! I'm in there as I do some other stuff anyway. I think the stupid kit that came with the wheel cylinder only had three shims, I'll have a look at that and compare with your description. Quote Link to comment
ggzilla Posted January 27, 2013 Report Share Posted January 27, 2013 Yes, there are three-shim/plate version and four-piece versions. I think Tokico used four pieces, and NABCO used three. I got a replacement SANYCO version that is like the Tokico. Datsun manuals are not very clear on this either. Quote Link to comment
ggzilla Posted January 27, 2013 Report Share Posted January 27, 2013 Found this in the 610 service manual. You can find factory service manuals as cheap as $5 if you watch ebay for a while. Quote Link to comment
DAT510 Posted January 28, 2013 Report Share Posted January 28, 2013 Those things were such a pain in the ass. 1 Quote Link to comment
Duncan Posted June 16, 2013 Report Share Posted June 16, 2013 Are these the same order on a 1200 also? Found a diagram in the Haynes manual.....Thanks but never mind :) Quote Link to comment
