Topher88 Posted January 23, 2013 Report Share Posted January 23, 2013 Ok as you can see my MC get REALLY close to my down pipe. My question is if I made a wedge that was 1/8-1/4 inche of mettle that would make the MC to angle away from the DP in turn making more room to put a heat sheild, Would that screw up all the geometry of the MC and cause pre mature wear or would it even work at all. Any help or advice would be appropriated. And in retrospect I should have gone with the Wilwood in cabin MC.. Quote Link to comment
D52E Posted January 24, 2013 Report Share Posted January 24, 2013 I would speculate that it could potentially casue unusual internal side loading in the master cylinder bore. This could lead to premature failure but I have not actually tried this proposed change to say with any certanty that it would be a problem. Quote Link to comment
ggzilla Posted January 24, 2013 Report Share Posted January 24, 2013 If it is 1/4" from the pipe, fit a heat shield to protect the master cylinder. Quote Link to comment
D52E Posted January 24, 2013 Report Share Posted January 24, 2013 Also, maybe consider thermal wrap on the downpipe? Edit - maybe ceramic coating of downpipe? Quote Link to comment
Dawa Posted January 24, 2013 Report Share Posted January 24, 2013 +1 on the heat shield. thatd be super easy to make and add kudos to your bay for having a custom diy heat shield Quote Link to comment
Uber Deaf One Posted January 24, 2013 Report Share Posted January 24, 2013 Ceramic coating, wrap AND a heat shield is what I would do. 1 Quote Link to comment
Lee R Posted January 24, 2013 Report Share Posted January 24, 2013 Might as well add a blanket on that turbo as well. Quote Link to comment
