Brody Posted January 23, 2013 Report Share Posted January 23, 2013 I'm having the hardest damn time trying to remove the head. My boss and I tried it for about two hours (he has a lot more experience with cars than I do) and we still couldn't get it off. Is there any trick to it or am I just not holding my tongue right? Quote Link to comment
Skib Posted January 23, 2013 Report Share Posted January 23, 2013 .... do you have all the bolts out? Quote Link to comment
Dat Lurka Posted January 23, 2013 Report Share Posted January 23, 2013 Engine? There's the head bolts and timing chain or rockers depending. If it's just stuck, smack it on the side with a wooden mallet a few times. That's how I got mine loose. Quote Link to comment
Brody Posted January 23, 2013 Author Report Share Posted January 23, 2013 Hahaha. Yes, all the bolts are out. And took everything off that I thought would effect it coming out. We've hit the hell out of it too. haha. Quote Link to comment
Skib Posted January 23, 2013 Report Share Posted January 23, 2013 well somethings prob still bolted down then Quote Link to comment
ggzilla Posted January 24, 2013 Report Share Posted January 24, 2013 Have you removed the rocker shaft yet? After removing rocker and head nuts (remember to do them in order, and in stages), the Factory Service Manual says: "To facilitate breaking of the cylinder head joint, tap each side of the head with a hammer using a piece of wood interposed to take the blow. Do not use excessive force. When lifting the head a direct pull should be given so that the head is pulled evenly up the studs." Quote Link to comment
dp320 Posted January 24, 2013 Report Share Posted January 24, 2013 If I remember correctly there are two threaded holes. 3/8" coarse thread I think. I can't remember exactly what I did but I had two eye bolts in my junk bolt collection that fit perfectly. I think I used those and found a place I could carefully lever on to pull the head up. I'd have to have the thing in front of me again. ETA, maybe I'm thinking of removing the bearings, not the head. Quote Link to comment
