imadriftking Posted January 23, 2013 Report Share Posted January 23, 2013 My project is a 1980 datsun 210 With KA swap haha i have put alot of money into just the swap got burnt on a ka24de motor so basicly paid $450 for a 96 5spd trans with light flywheel and exedy stage 2 clutch and short shifter. I Then found a ka24e that had all bearings and seals replaced along with gaskets got it for some work and $150 came with auto tranny and auto ecu. So the 96 5spd tranny bolted up perfect behind the 90 ka24e and since im using auto computer and ecu theres no speed gov and rev gov is up by 500rpm or soo. I have the engine and tranny installed just need to cut weld driveline and tranny mount. WIRING SUCKS!! haha i wired it through relays like diagram shows but only thing that kicks on is power wires from ecu no computer lights or fuel pump like injector wires have power when keys in on position. anyway here is some pics still currenty working on car. I NEED s13 ka24e ignition coil and ignitor $131 new :( http://i1292.photobucket.com/albums/ b561/imadriftking/80%20Datsun%20210%20with%20KA24E%20Swap/IMG124_zps57310317.jpg Quote Link to comment
imadriftking Posted January 23, 2013 Author Report Share Posted January 23, 2013 here is engine currently in 2 Quote Link to comment
imadriftking Posted January 23, 2013 Author Report Share Posted January 23, 2013 Also datsun sits on lowering springs and those tires u see in pic are sooo fat crazy handling gunna post pics of inside when done Quote Link to comment
sunny310 Posted January 24, 2013 Report Share Posted January 24, 2013 sweeetttttt brother!!! bet u can t wait to get that beast on the road huh?! Quote Link to comment
imadriftking Posted January 24, 2013 Author Report Share Posted January 24, 2013 Yea and the KA engine has everything extra tooken off and the intake butterflys in the lower part are always open this thing has every ounce of free horsepower squeezed outa it!! I cant wait just broke right now haha so its hard almost done though Quote Link to comment
superal30 Posted January 25, 2013 Report Share Posted January 25, 2013 Have any pictures of your engine mounts? I also have an 80 210 and bought a KA24e and trans, hopefully I'll be doing this same swap, as soon as my other projects calm down! Quote Link to comment
imadriftking Posted January 25, 2013 Author Report Share Posted January 25, 2013 Yea ill take pics tommarow for you Quote Link to comment
ggzilla Posted January 25, 2013 Report Share Posted January 25, 2013 Do you realize that by wiring the butterflies open you gain 3 HP at 5,000 RPM, but lose 20 HP at 2,000 RPM? Quote Link to comment
imadriftking Posted January 25, 2013 Author Report Share Posted January 25, 2013 Really?? Hmm so should they stay closed? Quote Link to comment
ggzilla Posted January 25, 2013 Report Share Posted January 25, 2013 No they shouldn't stay closed. Let them work as normal. Quote Link to comment
imadriftking Posted January 25, 2013 Author Report Share Posted January 25, 2013 I think u should use another method of motor mounts as i life in BFE and had to go wit what i got so as you can see in this pick i used stock datsun mounts and bolted it in the back two block holes from where 240 mount bolts up because they use 4 so use rear ill explain later. AND DONT MIND MOUNT POSITION ON THIS PIC the other side was not in at the time and also u can see i drilled a new hole because motor needed to be over a little Okay on the passenger side use same datsun mounts and no need for drilling. What i had to do was cut and bend in mount to fit starter it was too long and stock datsun mounts come off as a bar and 240 mounts like a j so starter wouldnt fit. YES THERE IS ROOM INBETWEEN STARTER AND MOUNT just cant see in pic also found out hard way u must put in starter b4 the mount :) OKAY so the reason for using back two holes from motor mount bolts in is because 1 on passenger side 240 front mount is lower on the front two bolts. and 2nd it gave room for pan so u dont have to mod that pic shows back of oil pan clearing no need to flip cross member still have to mod sway bar highly havent done that yet though Quote Link to comment
imadriftking Posted January 25, 2013 Author Report Share Posted January 25, 2013 Sorry wrong pic for 2nd pic here is good one Quote Link to comment
imadriftking Posted January 25, 2013 Author Report Share Posted January 25, 2013 . Quote Link to comment
ggzilla Posted January 26, 2013 Report Share Posted January 26, 2013 So those are the stock 210 engine mount brackets bolted to the KA? Quote Link to comment
imadriftking Posted January 26, 2013 Author Report Share Posted January 26, 2013 Yes you just have to drill holes a little bigger i forgot ot mention but yes Quote Link to comment
Dguy210 Posted January 26, 2013 Report Share Posted January 26, 2013 Is that the stock radiator? Quote Link to comment
ggzilla Posted January 26, 2013 Report Share Posted January 26, 2013 Stock 210 radiators are huge. The A/C versions are big enough to cool a KA, though the standard versions are not big enough. Quote Link to comment
Dguy210 Posted January 26, 2013 Report Share Posted January 26, 2013 Stock 210 radiators are huge. The A/C versions are big enough to cool a KA, though the standard versions are not big enough. Good to know as that is what I'm already running. :thumbup: Quote Link to comment
imadriftking Posted January 28, 2013 Author Report Share Posted January 28, 2013 Well theres a guy in my tawn has kaDe and has stock 210 radiator runs fine never overheats now for track use no but then again mabey hes lucky i have stock 210 radiator ill let u know how mine runs temp wise when i get mine finished Quote Link to comment
imadriftking Posted January 30, 2013 Author Report Share Posted January 30, 2013 Ok so i hooked up wiring exactly like diagram with relays and yes there hooked up correctly and they all work but when i turn on key my.computer and fuel pump dont kick on but i have power to injectors and power to coil Quote Link to comment
Z chopper Posted February 27, 2014 Report Share Posted February 27, 2014 I wonder if this would work in a 1200 sedan Quote Link to comment
ggzilla Posted February 27, 2014 Report Share Posted February 27, 2014 Why wonder? http://datsun1200.com/modules/mediawiki/index.php?title=KA_Engine_Swap Quote Link to comment
