Datso72 Posted January 20, 2013 Report Share Posted January 20, 2013 Does anyone know the name of the original shade of blue (???) on the air filter housing. I would like to repaint mine. Thanks. Quote Link to comment
ggzilla Posted January 20, 2013 Report Share Posted January 20, 2013 Datsun BlueDupont mix guide mix size806J HS BLACK 177.2801J HS WHITE 290.0828J HS FAST BLUE 373.8830J HS FAST GREEN 444.4702OG BINDER 844.07030G BALANCER 960.4 Quote Link to comment
Datso72 Posted January 20, 2013 Author Report Share Posted January 20, 2013 Datsun Blue Dupont mix guide mix size 806J HS BLACK 177.2 801J HS WHITE 290.0 828J HS FAST BLUE 373.8 830J HS FAST GREEN 444.4 702OG BINDER 844.0 7030G BALANCER 960.4 Thanks. Quote Link to comment
DanielC Posted January 20, 2013 Report Share Posted January 20, 2013 Thank you, I will be calling paint stores tomorrow. 1 Quote Link to comment
pharouh Posted January 20, 2013 Report Share Posted January 20, 2013 I took my air cleaner lid to the paint store,and they scanned the inside of it. (it was clean) then they mixed up a quart (minimum size I could get) and put part of it in a spray can. Wasn't spot-on but it was close. Quote Link to comment
DanielC Posted May 3, 2013 Report Share Posted May 3, 2013 This is a air cleaner lid off a 1974 620, and a bracket off a 1970 521 on top of it. The bracket was painted with Dupont Centari, Volkswagon Chrome Blue, VW code L51K I then took the lid back to the paint store, and they shaded the VW color to match the air cleaner lid. Quote Link to comment
DanielC Posted May 3, 2013 Report Share Posted May 3, 2013 I like Centari, but if you use activator or hardener in it, YOU MUST ABSOLUTELY BE SURE TO WEAR A RESPIRATOR WITH IT! Quote Link to comment
