Wheel bearings...
  • Replies 7
If you look them up on RockAuto.com all the dimensions will be listed althought the picture is wrong on one of the inners.
TIMKEN Part # 30304 Wheel Race; 0.7874 Cone Bore; 0.5906 Cone Width; 2.0472 Cup Outer Diam; 0.5118 Cup Width  Heart.png
Front Outer
SKF Part # BR31    {#4021073000} Wheel Race; Cup length=.5905"; Width=1.072"; Standout=.4823"; Outside diameter=2.5590"; Inside diameter=1.2600"; Cup radius=.0500"; Cone radius=.0800"; Cone length=1.0236IN
Front Inner (Only 3 Remaining)
There's a few more #'s listed here..... http://community.ratsun.net/topic/30875-320520521-inner-bearing-spacer/
I used to know the dimensions off the top of my head....all I can remember now is that the inner diameter is 32mm on the inner bearing.
......and I know you meant the "other" Mike :)
