Driveshaft for sale 83' +
So I got the driveshaft replaced after feeling a rumble -
First - I suspected the rubber-housed bearing on the driveshaft - it comes as two pieces knuckled together.  The output of the Trans is actually off-center - so to center it up - they made it angle after almost 14" after the trans output -
Turns out this driveshaft needs balancing - and there needs to be a machine press and a clamp to make the driveshaft properly.  Please buy this if yuo can use it - the bearing has 23 miles on it......
I linked to some pix - you can see the spline for the transmission...
http://thenovelsound.org/83-Ratsun/Driveshaft/2013-01-13_17-21-01_347.jpg
and the knuckle with the new rubber-enclosed bearing ( apparently a $200 value - but I will let this whole thing go cheap - name Best offer!
http://thenovelsound.org/83-Ratsun/Driveshaft/2013-01-13_17-20-05_429.jpg
All relevant pix at:
All general pix at:
ok
_________________________________________________________________________________________________________________________________________
  • Replies 4
