delariva Posted January 11, 2013 Report Share Posted January 11, 2013 Hi guys, I started rebuilding the carburetor that came with my 320. It is a Holley 5200 (part# R7343). I have it cleaned and replaced everything in the rebuild kit, but I am missing parts of the linkage, and all of the choke assembly and fast idle linkage. I am just throwing it out there to see if any of you have an old parts carb, or any of these parts you would like to sell. I attached a few pics of what I am missing if that helps. Thanks, Nick Link to comment
ggzilla Posted January 11, 2013 Report Share Posted January 11, 2013 That is a licensed version of a Weber 32/36 DFV. It says Weber down inside the fuel bowl. Link to comment
delariva Posted January 11, 2013 Author Report Share Posted January 11, 2013 Thanks. So if I can get my hands on a Weber 32/36 those parts should be interchangeable? Link to comment
karnutz Posted January 11, 2013 Report Share Posted January 11, 2013 I might have this carb for you. I'll check when I get home. Link to comment
ggzilla Posted January 11, 2013 Report Share Posted January 11, 2013 Perhaps, but Holley changed some things including the jets. Link to comment
bananahamuck Posted January 11, 2013 Report Share Posted January 11, 2013 So you only need just the 2 parts ?? the bent rod and the funny shaped lever thingamabob? Link to comment
delariva Posted January 11, 2013 Author Report Share Posted January 11, 2013 So you only need just the 2 parts ?? the bent rod and the funny shaped lever thingamabob? That's all I need for the throttle linkage, but I also need all of the fast idle linkage parts as well as the choke assembly. When I get home I'll post a pic of my carb. Link to comment
delariva Posted January 11, 2013 Author Report Share Posted January 11, 2013 I might have this carb for you. I'll check when I get home. Thank you. Link to comment
delariva Posted January 11, 2013 Author Report Share Posted January 11, 2013 Thanks for trying anyway karnutz. Here are the pictures of the carb I have and what is missing on the choke assembly etc. Link to comment
crackerjack69 Posted January 12, 2013 Report Share Posted January 12, 2013 Dang. I've got a holley in the garage. Saw this, ran out and grabbed it. Doesn't appear to be quite the same as yours. Link to comment
ggzilla Posted January 12, 2013 Report Share Posted January 12, 2013 Yours might be a Holley 5210 Link to comment
delariva Posted January 14, 2013 Author Report Share Posted January 14, 2013 Yours might be a Holley 5210 This is the carb i have according to the stamp on the base of the carb. It says H2-5200 It has the weber stamp in the bowl like you said it would too. http://www.carburetion.com/CarbNumber.asp?Number=R7343 My buddy just gave me his old weber 32/36. he just did an engine swap and didn't need it anymore. I would still like to finish the other carb rebuild since i put the time and money into it. I'll keep searching the pick n pull, but It's been tough to find. Link to comment
