Brock510 Posted January 7, 2013 Report Share Posted January 7, 2013 Looking for either of these if you have them and you don't need them please contact me thank you. I posted in the for sale section accidentally. My appologies. Link to comment
datzenmike Posted January 7, 2013 Report Share Posted January 7, 2013 There were 3 kinds, I assume an L series for a 510? Link to comment
ggzilla Posted January 7, 2013 Report Share Posted January 7, 2013 510s came with 5-speeds? For which dogleg transmission do you need the front case? None of the doglegs have a removable bell housing. Link to comment
datzenmike Posted January 7, 2013 Report Share Posted January 7, 2013 There were 3 kinds, I assume an L series for a 510? I said for, not from. :) Bolt pattern for a Z series NAPS motor Bolt pattern for an L series motor David it giving you the gears. The dogleg has a front and rear aluminum case sandwiching a steel adapter plate that holds all the gears. The bell housing is integral with the front case. I believe you were asking about the long dogleg? You can see the tail is much longer. . Link to comment
Brock510 Posted January 7, 2013 Author Report Share Posted January 7, 2013 I have a naps z and also another z trans that can't remember at the moment. I remember reading that u could swap the front cases from dogleg to naps z Link to comment
Brock510 Posted January 7, 2013 Author Report Share Posted January 7, 2013 And I know the main way to tell a naps z is by the 7 bolts on the inside of bell housing the seven bolts by the input shaft Link to comment
Brock510 Posted January 7, 2013 Author Report Share Posted January 7, 2013 Here's the write up I read just for accuracy purposes. http://community.ratsun.net/topic/19046-i-thougt-a-dogleg-trans-was-a-direct-bolt-in-swap-into-510/page-2 Link to comment
datzenmike Posted January 7, 2013 Report Share Posted January 7, 2013 The term NAPS is a style of pollution control used on several motors but generally people call any Z series motor a NAPS motor. Z series or NAPS motors have a different alignment or lean, in the engine compartment and thus the bolt pattern is also clocked differently between L and Z series transmissions and thet can't be interchanged. You can remove the front cases and swap them though to convert them. Dogleg transmissions are different from all other 5 speeds and they come in L and Z (NAPS) bolt patterns. The front cases can be swapped but only between an L and Z series transmission. Link to comment
