gokiburix
GOONS check in
Floor mods to handle that height?
No, all we did is a 3 inch block, dropped trans crossmember a half inch because the way previous owner had it mounted placed trans right against floor, and a 4 degree pinion angle shim occasionally on hard bumps driveline will hit floor but some shocks should help with that since the ones on it are blown
Share this post
Link to post
Cool.  :thumbup:
And I'm sure that helps a lot...   ^_^
Share this post
Link to post
Who here is going to drive their Wagons to the 2018 Mitty the end of April at Road Atlanta?
Share this post
Link to post
Heres my goon picked this one up in december, its my daily until i have all the parts for my sr swap and ford 8.8 swap, let me know ehat you guys think !
Nice Goon.
Share this post
Link to post
I wish I could.
Share this post
Link to post
Very nice  ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ :thumbup:
Share this post
Link to post
Agreed
Share this post
Link to post
Gettin' badass groceries in that for sure.
Share this post
Link to post
Took off the Weber with hirise manifold to put this shorter adaptor on just have to get the studs out.
After that the stock linkage should work. Next the gas tank gets put in. Gotta get this Goon going!
Share this post
Link to post
Finally got the Weber 32/36 DGV on the Goon now the linkage should work. Next up the gas tank.
Share this post
Link to post
Whent to the house hooked up the spring that connects to the throttle linkage back up, stepped on the gas peddle and it whent down and back up correctly. Wow now I have a Weber 32/36 DGV on my Goon. Hope I can install the gas tank befor the end of April. That way I should have the Goon cranking and driving again.
Share this post
Link to post
Found a elec distributor and coil as well as most of what I need for under the hood except a battery for the Goon.
Share this post
Link to post
Modified and fitted the original dash cluster and changed the mounting for the addition gauges during the week, then took it to a cars and coffee meet today.
https://imgur.com/u72Etur
https://imgur.com/PdgIh2H
https://imgur.com/a/b436Csn
https://imgur.com/sHXesyu
https://imgur.com/yR0dSSR
Very nice Goon there.
Share this post
Link to post
No gas leaks when I put fuel in, but could not get to fire last week so today I have to see what I overlooked.
My guess is I probably put a points distributor rotor in a elec distributor. We'll see.
  • Like 5
Share this post
Link to post
Ok now the Goon is turning on and going on its own.
She still needs plenty of work.
  • Like 3
Share this post
Link to post
