SHAMUS'WAGON Posted January 4, 2013 Report Share Posted January 4, 2013 Snapped off all three water outlet bolts on my 620, and i cant get the top off of the housing. I have two bolt outlets, but I don't feel like changing the bypass routing until I start the de-smogging project. I'm looking for a cheap three bolt water outlet to get me going again. I just need the bottom portion that bolts to the head. Prefer local, but can pay shipping if I have to. Thanks for looking. Link to comment
jefe de jefes Posted January 4, 2013 Report Share Posted January 4, 2013 I think I have one but it's in Cali. Hit me up on Sunday if you haven't found one locally by then. Link to comment
philcas1987 Posted January 5, 2013 Report Share Posted January 5, 2013 sol...haha I told you I hate those. Link to comment
datzenmike Posted January 5, 2013 Report Share Posted January 5, 2013 The by pass is just rubber hose. Cut a longer piece for it. Link to comment
Dawa Posted January 5, 2013 Report Share Posted January 5, 2013 snapped from over torquing or when removing? guess its time to upgrade those bolts, too! Link to comment
Ranman72 Posted January 5, 2013 Report Share Posted January 5, 2013 you should post this in the parts wanted section Link to comment
datzenmike Posted January 5, 2013 Report Share Posted January 5, 2013 Just use an anti seize compound when installing them. Moved Link to comment
banzai510(hainz) Posted January 6, 2013 Report Share Posted January 6, 2013 you could go to a 2 bol tif you wanted to key is anti seize and make sure no waterin the hole. I stat was never replaced the bolts can shear off. als the temp sender 16mm hex nuts are a bitch also and usually crack the housing. so best to get a spare in case. i use stainless bolts in them now Link to comment
