280z dashboard in a 240z
  • Replies 10
240z had a/c as a dealer option. You dont need to go through all that trouble. I believe msa still sells brand new kits.
They arent direct and the 240z dash looks 10x better imho.
I hear you about the controls, designed in and retro'd in are def dif. That said though for the trouble of doing all this dash swapping you could either just do a tasteful trick install on a 240 or do it on a native 280z and be done with it then and there.
Lots of wires to sort out
the 240 dash is better looking even with an add on switch
if you don't like the add on switch put it in a hidden location
but its your car if your good with wiring and really want to do the swap post lots of pics to share info here BUT I would never do that myself
