bikesnbenzs Posted December 31, 2012 Report Posted December 31, 2012 i have a loose hose coming off the back of the brake booster ,the main vac hose on the front is all good just wondering where the second hose attaches Quote
ggzilla Posted December 31, 2012 Report Posted December 31, 2012 It does not attach to the brake booster. Pull on it to see where it comes from. Quote
bikesnbenzs Posted December 31, 2012 Author Report Posted December 31, 2012 its coming off that back of the booster , not sure where it goes on the motor Quote
datzenmike Posted December 31, 2012 Report Posted December 31, 2012 Take a long look at it. The main vacuum line is on the front of the booster, likely on the fender side of the master cylinder. It goes over to a metal one way valve mounted on the fire wall. From there it connects to a short metal pipe that screws into the intake manifold. There is no other pipe or hose going to the brake booster. The booster itself sits on a small pedestal that holds it out from the fire wall by several inches. Perhaps post a picture of it. Quote
