73DATSON Posted December 20, 2012 Report Share Posted December 20, 2012 Ok i see alot of mods going on here. I would like to hear from all of you on how much HP your lil RATSUN is pushing??? When i get my WEBCAM put in i'll be heading to the dyno,then i'll put my input. So don't be SHY :blush: And and your MODS :thumbup: Quote Link to comment
h190 Posted December 20, 2012 Report Share Posted December 20, 2012 250-260. Factory sr20det 13lbs of boost. Quote Link to comment
73DATSON Posted December 20, 2012 Author Report Share Posted December 20, 2012 250-260. Factory sr20det 13lbs of boost. SWEET THAT'S WHAT IM TALKING ABOUT!!!! Quote Link to comment
karnutz Posted December 20, 2012 Report Share Posted December 20, 2012 375hp bridgeport 13b. turbo yet to come! 2 Quote Link to comment
73DATSON Posted December 20, 2012 Author Report Share Posted December 20, 2012 375hp bridgeport 13b. turbo yet to come! I LOVE ROTARY!!!! I'm still thinking of getting one:-)))) what kind of mods need to be done to get a 13b in a DATTO??? Quote Link to comment
banzai510(hainz) Posted December 20, 2012 Report Share Posted December 20, 2012 73 write this down Im thinkn you might hit 100hp at rear wheels or with in 10hp and ill add that to the high side. Quote Link to comment
karnutz Posted December 20, 2012 Report Share Posted December 20, 2012 Not much really. Drive shaft, trans x-member, modify front x-member, modify firewall to clear slave cyl, wiring and fuel system, and add oil cooler. Quote Link to comment
73DATSON Posted December 20, 2012 Author Report Share Posted December 20, 2012 73write this down Im thinkn you might hit 100hp at rear wheels or with in 10hp and ill add that to the high side. You really think 100@the wheels? I was hoping for more:-(( Quote Link to comment
73DATSON Posted December 20, 2012 Author Report Share Posted December 20, 2012 Not much really. Drive shaft, trans x-member, modify front x-member, modify firewall to clear slave cyl, wiring and fuel system, and add oil cooler. Do you have a write up on the install? Quote Link to comment
karnutz Posted December 20, 2012 Report Share Posted December 20, 2012 No. But I'm sure I could put something together if there was enough interest. Quote Link to comment
vegasS12 Posted December 20, 2012 Report Share Posted December 20, 2012 Hopefully my set up (built and sleeved SR) in the S12 will be seeing 550hp with the gt3076R Quote Link to comment
73DATSON Posted December 20, 2012 Author Report Share Posted December 20, 2012 No. But I'm sure I could put something together if there was enough interest. Let me tell you I'm interested in doing it!!!! I had a 13BRE Cosmo in a 84 RX7. Bought it like that I love that car!!!! Had to sell:-((( wish I never did!!! No rush with the write up just don't forgot me please.... Quote Link to comment
73DATSON Posted December 20, 2012 Author Report Share Posted December 20, 2012 Hopefully my set up (built and sleeved SR) in the S12 will be seeing 550hp with the gt3076R KEEP IT COMING WITH THESE HIGH #!!!! Loving it. Quote Link to comment
73DATSON Posted December 20, 2012 Author Report Share Posted December 20, 2012 Come on now I would love to hear from my L MOTORS?? Let my see those #?? Quote Link to comment
karnutz Posted December 20, 2012 Report Share Posted December 20, 2012 The hardest part to the swap is the notch in the front x-member. Without it the motor won't sit low enough. I did mine then didn't like the looks of it so I had a buddy cnc one in aluminum and you also need to decide which way you want to mount it first(conventional side mounts or front plate). Once your through that step its really pretty easy. I had my tranny mount cnc'd to for aesthetic reasons. Quote Link to comment
73DATSON Posted December 20, 2012 Author Report Share Posted December 20, 2012 The hardest part to the swap is the notch in the front x-member. Without it the motor won't sit low enough. I did mine then didn't like the looks of it so I had a buddy cnc one in aluminum and you also need to decide which way you want to mount it first(conventional side mounts or front plate). Once your through that step its really pretty easy. I had my tranny mount cnc'd to for aesthetic reasons. Well I saw a front mount already. I was told to use a 12a oil pan so you don't cut into the cross member? Quote Link to comment
ssnapz Posted December 20, 2012 Report Share Posted December 20, 2012 stock napz24, mild cam, 350cfm holley, home made header, 8mm wires, guessing 150 @ the flywheel. planing a turbo and possible r1 carbs. want to get it on the dyno before anymore upgrades though Quote Link to comment
73DATSON Posted December 20, 2012 Author Report Share Posted December 20, 2012 stock napz24, mild cam, 350cfm holley, home made header, 8mm wires, guessing 150 @ the flywheel. planing a turbo and possible r1 carbs. want to get it on the dyno before anymore upgrades though[/quote Nice. R1crabs y? R they better to use? Quote Link to comment
karnutz Posted December 20, 2012 Report Share Posted December 20, 2012 I went conventional. Didn't feel like cluttering up the front of the eng compartment. It's got enough going on with oil lines etc. plus that gives me room to mount the turbo when I inject it down the road. Quote Link to comment
DAT510 Posted December 20, 2012 Report Share Posted December 20, 2012 I went conventional. Didn't feel like cluttering up the front of the eng compartment. It's got enough going on with oil lines etc. plus that gives me room to mount the turbo when I inject it down the road. Do you have a build thread? I'm very interested in this. Quote Link to comment
DAT510 Posted December 20, 2012 Report Share Posted December 20, 2012 Oh and I probably have 70hp at the wheels, if the temp outside is cold. :lol: Quote Link to comment
karnutz Posted December 20, 2012 Report Share Posted December 20, 2012 I don't. But I guess I should put one together. Most Datsun fanatics slag me for the rotary so I never bothered. 1 Quote Link to comment
73DATSON Posted December 20, 2012 Author Report Share Posted December 20, 2012 You See U talked and they will come:-)))) Quote Link to comment
karnutz Posted December 20, 2012 Report Share Posted December 20, 2012 I've built L's, z's and ka's and found I'm getting way more bang for my buck with the rotary. Plus they sound insane once they are ported!!! Lol. Quote Link to comment
DAT510 Posted December 20, 2012 Report Share Posted December 20, 2012 I don't. But I guess I should put one together. Most Datsun fanatics slag me for the rotary so I never bothered. Fuck em lol. They're probably the same ones that put a SR20 in a 510. or a LS1 in a Z. So what if a rotary is in a Datto, hell even Datsun was going to put a rotary in a Datto. I think it's wise to start a build thread just because it's always nice to have a documented build, just in case something went down. 1 Quote Link to comment
