mhub91 Posted December 10, 2014 Report Share Posted December 10, 2014 I think Hamuck is right...... There are also a few A10s out there with SR20DET swap, but it seems they're stuck in limbo and will never see the road..... There are popular in Australia, though. They're called "Stanza" there. Go check out Ozdat.com Quote Link to comment
datzenmike Posted December 10, 2014 Report Share Posted December 10, 2014 I have called it FAPG the whole time I have been with Toyota. After a while, my parts guy corrected me. "Wrong!" I said. "FAPGoo." 1 Quote Link to comment
Raggleflaggle Posted December 10, 2014 Report Share Posted December 10, 2014 Has anyone ever discussed putting the 240sx rear into a A10 coupe? Quote Link to comment
mhub91 Posted December 10, 2014 Report Share Posted December 10, 2014 240sx is independant rear suspension, much like the Z cars and PL510, whereas an A10 is 4 link (like the 210) for sedans and coupes, and the wagon is a leaf spring setup. an H190 from a 200sx bolts right into an A10. Much stronger, and some even came with disc brakes! Which brings up a question I've had for a while now -- Does anyone know if the Nissan Hardbody's LSD H190 center (solid axle) will bolt into a 200SX' H190 housing (4-link) ?? If so ..... mother of god. A10 with an LSD H190?! Keep in mind, you can just swap the H190 from a D21 into a wagon, as theyre both leaf springs. Granted, you would probably need a different driveline. fffuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu..... 1 Quote Link to comment
Raggleflaggle Posted December 10, 2014 Report Share Posted December 10, 2014 I know, but good luck finding one. In the south no less. Z cars are just about all that's left, hardly any trucks anymore. I have a z car at my disposal... But I like your hard body idea better surely to be one of those around. Quote Link to comment
datsunfreak Posted December 11, 2014 Report Share Posted December 11, 2014 68-73 510 wagon is also a leaf spring H190. Quote Link to comment
Fat510 Posted December 11, 2014 Report Share Posted December 11, 2014 He stock A10 rear end is a H165. A solid axle would be better and way easier than converting to IFS Quote Link to comment
Raggleflaggle Posted December 11, 2014 Report Share Posted December 11, 2014 Talking more on the theoretical side with that. Not really going to happen, but I'm just asking more about what I have and if there's any major hurdles besides "not easy". As for an original 510, if I find one in AL it will be ethier A) Rebuilt b) a complete car I won't want to destroy or C) way too much money. So that kinda gets theoretical due to lack of parts. Quote Link to comment
Burabuda Posted December 12, 2014 Author Report Share Posted December 12, 2014 this was spotted @ the recent socal mazda meet 1 Quote Link to comment
mhub91 Posted December 12, 2014 Report Share Posted December 12, 2014 The coupe is most likely the rarest of all A10s, but I don't like the 'fast back' look. I do, however, really like the 2 door sedan. Now that's sex. On the topic of how uncommon A10s are, it seems like the wagon is most common, followed by the 4 door sedan. In my opinion the hatch back, like what Alexmeans has, is fairly uncommon too. But... I don't think I've ever seen a coupe in real life. I have seen two 2 door sedans. Really really like them. 2 Quote Link to comment
Burabuda Posted December 12, 2014 Author Report Share Posted December 12, 2014 what about the 4 door hatch? Quote Link to comment
mhub91 Posted December 12, 2014 Report Share Posted December 12, 2014 i meant 4 door hatch when i said hatch. the 2 door / hatch / lift back thing is actually a coupe Quote Link to comment
mhub91 Posted December 12, 2014 Report Share Posted December 12, 2014 alexmeans has a 4 door hatch square headlight Quote Link to comment
datzenmike Posted December 13, 2014 Report Share Posted December 13, 2014 Which brings up a question I've had for a while now -- Does anyone know if the Nissan Hardbody's LSD H190 center (solid axle) will bolt into a 200SX' H190 housing (4-link) ?? If so ..... mother of god. A10 with an LSD H190?! Keep in mind, you can just swap the H190 from a D21 into a wagon, as theyre both leaf springs. Granted, you would probably need a different driveline. fffuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu..... Yes it would bolt in... BUT.... The LSD side gears are for 29 spline truck axles. The S110 H-190 would have 23 spline side gears. The D21 axle assy is massively wide and 6 bolt lugs. Sexy but no one would know if it was LSD and the A10 doesn't spin one tire all the way through third gear to need it. Quote Link to comment
mhub91 Posted December 13, 2014 Report Share Posted December 13, 2014 Datzenmike, you're always on with info. Thanks! Wonder if it's possible to get the 23 spline axles machined to a 29 spline axle? Quote Link to comment
datzenmike Posted December 13, 2014 Report Share Posted December 13, 2014 The LSD would have 29 spline. You would want 29 spline on your 23 spline on the S110 axles. The problem arises because of the LSD. On an open differential you could simply swap the 23 and 29 spline side gears inside. The LSD side gears have to fit the clutch and disc layers on each side. If there were 23 spline... OK I'm back. There actually was 23 spline LSD side gears for an LSD H-190. The early Roadster if you can find them. The part number is 38423-16300 but confirm this. 1 Quote Link to comment
mhub91 Posted December 14, 2014 Report Share Posted December 14, 2014 Seems like an over over kill to have a H190 on a roadster.... Quote Link to comment
datsunfreak Posted December 14, 2014 Report Share Posted December 14, 2014 Seems like an over over kill to have a H190 on a roadster.... It was overkill in a 510 wagon too... :rofl: Why they'd use an H190 in an underpowered L16 510 wagon, then turn around and use an H165 in a heavy 200SX with a torquey Z20E is beyond me... Quote Link to comment
mhub91 Posted December 14, 2014 Report Share Posted December 14, 2014 Actually the Z20E 200SX had an H190 too, with drum rear brakes. Was talking about first year S12 came out.... Not the S110 lol Quote Link to comment
datsunfreak Posted December 14, 2014 Report Share Posted December 14, 2014 Actually the Z20E 200SX had an H190 too, with drum rear brakes. Never seen that. Ever. I would bet cash money every USDM S110 200SX had disc brakes. And every Z20E came off the assembly line with the H165, and the Z22E cars had the H190. My S110 FSM doesn't even show drum brakes on any model. I've bought no less than 5 200SX diffs that were disc brake and H165. And the only H190 I've ever seen in one was a Z22E car. But stranger stuff has happened.. I have seen an '84 (S12) 200SX with drum brakes on an H190. Maybe someone swapped one into an S110... Quote Link to comment
mhub91 Posted December 14, 2014 Report Share Posted December 14, 2014 Mother of god, where did I get my facts from?? Sorry, I was getting confused with the S12 200sx, as the very first year (84?) had a 4 link setup with drum brakes with an H190. When I said Z20E for whatever reason my mind went to the first gen S12, even though there's no relation there haha. Quote Link to comment
datsunfreak Posted December 14, 2014 Report Share Posted December 14, 2014 Mother of god, where did I get my facts from?? If it's any consolation, I thought you lost your mind too... :rofl: 1 Quote Link to comment
yellowgoon Posted December 15, 2014 Report Share Posted December 15, 2014 The new motor for the wagon http://rs44.pbsrc.com/albums/f33/Anthonie_Haag/Mobile%20Uploads/IMG_20141213_181738269_zpsaebde947.jpg~320x480?t=1418598996 Quote Link to comment
yellowgoon Posted December 15, 2014 Report Share Posted December 15, 2014 http://rs44.pbsrc.com/albums/f33/Anthonie_Haag/Mobile%20Uploads/IMG_20141213_181635286_zpsad432e2c.jpg~320x480?t=1418599043 Quote Link to comment
