REDnGOLD Posted December 13, 2012 Report Share Posted December 13, 2012 Did a search but i found several info on d rear but not d front. I know on later years, for both cars, brakes & rotors are d same. Will a 72 510 front disc rotors fit 74 610 brake calipers? thnx If this is a repost i apologize. I just didnt find any info on google. Maybe i wasnt typing the right question. Quote Link to comment
banzai510(hainz) Posted December 13, 2012 Report Share Posted December 13, 2012 go to rockauto.com and enter the years and if the part number the same you know the awnser. I believe they were. at least 73 Quote Link to comment
Dawa Posted December 13, 2012 Report Share Posted December 13, 2012 ^ was gonna say the same thing (rockauto.com) aha Quote Link to comment
REDnGOLD Posted December 13, 2012 Author Report Share Posted December 13, 2012 Rockauto. I completely forgot about that. Thanks Banzai. I did d search. While the rotors arent similar, the calipers for both cars, of said years, are. Same similar parts number. YEY!! Quote Link to comment
izzo Posted December 13, 2012 Report Share Posted December 13, 2012 similar parts numbers? eh.. i wouldn't go off similar part numbers, they are different part numbers for a reason. According to rockauto the 510 brake rotors will fit a 73 610, doesn't show 74. the 74 stock 610 rotor is 5mm shorter than the 510 rotor. 510 is 40.1, and 74 610 is 35.5. A difference of 4.6MM, or 0.18" Quote Link to comment
REDnGOLD Posted December 13, 2012 Author Report Share Posted December 13, 2012 here is what i found Quote Link to comment
izzo Posted December 13, 2012 Report Share Posted December 13, 2012 lol. I read the question, will a 72 510 rotor fit a 610 caliper. I assumed you had a 72 rotor laying around, and wanted to use it on a 74 610 and didn't know if it would work/clear the caliper properly... Idk, i just went off what I read from your OP.. Maybe I misunderstood the ? Quote Link to comment
REDnGOLD Posted December 13, 2012 Author Report Share Posted December 13, 2012 i also called Rockauto to confirm & its a GO Quote Link to comment
REDnGOLD Posted December 13, 2012 Author Report Share Posted December 13, 2012 I recently just aqcuired a shortened 72 510 struts/rotor assembly to go on my 74 610 but the rotors are bad. So, im looking around to purchase a used 510 rotor. But before i do that i wanted to know if it will fit my 610 brake calipers. I dont have d 510 struts & rotors at the moment to test it on my 610. lol. I read the question, will a 72 510 rotor fit a 610 caliper. I assumed you had a 72 rotor laying around, and wanted to use it on a 74 610 and didn't know if it would work/clear the caliper properly... Idk, i just went off what I read from your OP.. Maybe I misunderstood the ? Quote Link to comment
