datzenmike Posted December 4, 2012 Report Share Posted December 4, 2012 These are substitutes for the OEM molded hoses that are hard to find, expensive or non existing. They may fit 610/710s too or any application that needs a 90 degree molded heater hose. This was posted by Byron on The 510 Realm so thank you Byron. Single pass heater core alternative to OEM hoses for the interior side of heater assembly. Dayco 86121 (2005 Kia Optima, 1989 Geo Spectrum, 1991 Chec Cavalier) can be utilized for both pieces – in fact you can make two sets out of the one hose! Carburetor heat riser bypass hose alternatives to OEM, This is the line that runs from under the carb to the coolant inlet around the front of the motor when utilizing the stock OEM metal pipe. Dayco 80394 (2004 Grand Vitarta, 1989 Honda Accord); Again this hose can be cut to fit both the 90 degree bend and the strait section required for installation of this bypass pipe. 3 Quote Link to comment
DanielC Posted December 4, 2012 Report Share Posted December 4, 2012 If looks like the second hose would fit on a L-16 in a 521. The water inlet to intake manifold hose. The top hose may be useful in hooking up the heater on a 521, but i think some extra pieces would be needed. Quote Link to comment
skyblue Posted December 4, 2012 Report Share Posted December 4, 2012 wow tha'ts a great alternative. thx for sharing. Quote Link to comment
banzai510(hainz) Posted December 4, 2012 Report Share Posted December 4, 2012 521 the metal from heater ,line is smaller I believe than the 510 one. this should be posted on olddatsuns.com also parts swap or something 510 hoses are still avail but the 521s are harder to find now I think. Quote Link to comment
datzenmike Posted December 4, 2012 Author Report Share Posted December 4, 2012 wow tha'ts a great alternative. thx for sharing. Well Byron posted it on of The 510 Realm I just brought it here. Quote Link to comment
Ryan Family 510 Posted January 22, 2015 Report Share Posted January 22, 2015 Very helpful, thank you Quote Link to comment
Humboldt Posted June 11, 2016 Report Share Posted June 11, 2016 Somewhat on topic . . . does anyone have a source for Water Inlet Gasket for L16? I have searched all over. Thanks Quote Link to comment
DanielC Posted June 11, 2016 Report Share Posted June 11, 2016 Try your local Nissan dealer. 1 Quote Link to comment
Humboldt Posted June 11, 2016 Report Share Posted June 11, 2016 Lame of me , but I presumed they wouldn't have it. I will check Monday, thanks. Quote Link to comment
Humboldt Posted June 15, 2016 Report Share Posted June 15, 2016 Thanks! I ordered it and a couple xtras from Morlan Niisan in MO. Part number for Water Inlet Gasket: 13050-07N00 2 Quote Link to comment
banzai510(hainz) Posted June 15, 2016 Report Share Posted June 15, 2016 Fepro front cover kits have them also. I usually don't remove those from the front cover 1 Quote Link to comment
datzenmike Posted June 15, 2016 Author Report Share Posted June 15, 2016 Somewhat on topic . . . does anyone have a source for Water Inlet Gasket for L16? I have searched all over. Thanks Make your own!!! Go to dollar store and buy a round hole punch, borrow kitchen scissors. Trace out gasket on cereal box. Hole punch the bolt holes. Hole punch the larger opening so you can finish with scissors and you are done. Do NOT use rtv just put it on and forget it. Use anti-seize compound on the bolts. I have cereal box thermostat cover and mount gaskets on my 710 right now and I'm about 1,500 miles into my travels. I never worry about gaskets. 1 Quote Link to comment
yenpit Posted July 6, 2020 Report Share Posted July 6, 2020 If anybody is interested, one issue when doing a CA SR or KA swap in a 510 is that some installations push these engines far back enough to hinder the ability to hook up the stock heater hoses! We just did a CA18DET swap with this problem, so I pulled off the stock heater valve (most don't work anyway) & the two brass heater pipes that poke thru the firewall, bought a couple of Dayco #80407 heater hoses with a 90deg pre-formed bend at one end, ran them from the heater core over to the passenger side, looped thru the firewall (like the dealer installed AC hoses!) & then back to the engine. I installed the hoses on the engine BEFORE installing the engine, cuz the inlet & outlet are difficult to get to with the engine stuffed in the 510! I also installed a simple universal heater valve in the correct hose under the dash, made a new LONGER heater cable from a lawnmower solid core throttle cable & was able to use the stock ON-OFF heater slide control! Should work great for our random weather changes here in the Spring & Fall! 3 Quote Link to comment
G8KeaPoR Posted August 13, 2020 Report Share Posted August 13, 2020 (edited) I had this issue on my RX-7 when I scrapped the tiny sequential hitachi turbos for a big T-72 turbo, Honestly I found hat steel braided one would hold a shape... Well mostly. There is also this plastics braid that if you heat gun it it will hold its shape. For any serious bends I just used some aluminum tubing, a pipe bender or welder for 90’s, and a double flange tool. It looks fantastic and I don’t have to worry about blowing out a line at the bends. Not sure on the dime but that happens quite a bit on the dorritos.. Edited August 13, 2020 by G8KeaPoR Quote Link to comment
G8KeaPoR Posted August 13, 2020 Report Share Posted August 13, 2020 On 7/6/2020 at 12:56 PM, yenpit said: If anybody is interested, one issue when doing a CA SR or KA swap in a 510 is that some installations push these engines far back enough to hinder the ability to hook up the stock heater hoses! We just did a CA18DET swap with this problem, so I pulled off the stock heater valve (most don't work anyway) & the two brass heater pipes that poke thru the firewall, bought a couple of Dayco #80407 heater hoses with a 90deg pre-formed bend at one end, ran them from the heater core over to the passenger side, looped thru the firewall (like the dealer installed AC hoses!) & then back to the engine. I installed the hoses on the engine BEFORE installing the engine, cuz the inlet & outlet are difficult to get to with the engine stuffed in the 510! I also installed a simple universal heater valve in the correct hose under the dash, made a new LONGER heater cable from a lawnmower solid core throttle cable & was able to use the stock ON-OFF heater slide control! Should work great for our random weather changes here in the Spring & Fall! Could you put a light bend in the tubes so they come out at an angle? Never done that swap so if that’s a useless suggestion my apologies. Quote Link to comment
yenpit Posted August 16, 2020 Report Share Posted August 16, 2020 On 8/13/2020 at 2:50 AM, G8KeaPoR said: Could you put a light bend in the tubes so they come out at an angle? Never done that swap so if that’s a useless suggestion my apologies. Nah, the OEM tubes only stick out of the firewall about 2in, so no length to bend! We just got a KA swapped 510 in our shop, I think the engine is mounted far enough forward that we can re-install a heater box (previous builder did not install) with the stock tubes. I hope the same Dayco #80407 hoses with the 90deg preformed bend will work! Quote Link to comment
Icehouse Posted April 4, 2021 Report Share Posted April 4, 2021 We just reclock the cock and run the hoses inside the car on swaps. 4 Quote Link to comment
iceman510 Posted May 27, 2021 Report Share Posted May 27, 2021 I bought the 86121 hose and it worked perfectly for my heater rebuild. In fact it could yield enough hose to do two vehicles. 👍 1 Quote Link to comment
Diabolic kustoms Posted May 4, 2022 Report Share Posted May 4, 2022 Just found out that automatics use different hoses.. well the long one from the water pump is different.. and nobody has them... just going to use a straight piece I guess. Quote Link to comment
