EPIC DIY $20 Camber Plates RATSUN STYLE ! ! !
VintageRice
SO, I needed some neg camber, to lower my 510 more while preventing tire rubbage. Plus good for handling right.......so
T3 plates are amazing, but I'm a budget guy, so $200 is a big chunk o change.
Every time I see adjustable plates on someones car they are set maxed out negative. I'm guessing other than auto-x guys most people just set them and forget them.
So I figured why not just make some non-adjustable plates. Simple design, just like stock, bolts up to a single hole and stays there. Sooooo......
Went to Everett steel, asked the guy there(classical music listening guy, some may know who I'm talking about, super nice dude) asked him if they had any pre-cut circles in 1/4"
He said 3 inch and 12 inch.......hmmmm dang, so I said, nothing in 6 inch? He said yeah, 3/8th thick. I said I'll take two. $7~ each.
Next stop, hardware store, got some sweet nuts and bolts and headed home.
Checked the strut towers with the discs and omg PERFECT fit. dude........cool. :w00t: :thumbup:
Drilled a few holes and threw some paint on and wha-la. Camber. For about 20 bucks. DONE. :thumbup:
oics
Start
Duplication
Bolted up and DONE.
Slammed on its nutz(i'm going to have to raise it a little till my exhaust gets tucked better lol)
After a summer of light driivng on my cheapo ebay coilovers, those cheap plastic top hats are thrashed! Check it out! (ordered some billet T3 hats for $20 today) :D
  • Like 4
  • Replies 52
Epic Ratsun style camber! I would love some details on hole placement, bolt holes, ect. I have access to a plasma cnc and I would love to pump out a couple sets for some friends to try out. BTW, that guy at Everett steel is cool as shit ;)
I've used plasma cnc(was my high school job for a few years) and also got my intake and exhaust flanges cut by a plasma outfit last spring. Lemme tell you, my drill press holes are MUCH more precise than the blow through holes and angled cuts that plasma provides. Not being sarcastic either. Maybe there's better machines out there, but water jet would be the only way to go to get the holes nice and straight and round and not sloppy. Plus, holding the plate up there and making marks with a sharpie is SOOOO much ezier than drawing up a CAD file lolol Just sayen..
Making both sides match, I would say, is much more critical than the initial measurements. Being a degree or two off on the camber wont be noticeable. As long as both wheels are the same.
^ So true! I was hoping to be lazy and you would provide me with a cad drawing I could just send to my buddy ;) However I can manage a 6" circle cad file and drill them myself :P From the pictures it looks like your top bolt is flush / slightly above the stock mount point so in effect your getting a touch lower with these?
Much lower. It eliminated the stock 510 top hat I WAS using and now the strut is bolted straight to the plate. So got like 1.5"-2" more drop without even moving my coilovers.
Although, I do realize now that I need to put a bearing in there between the top hat and the plate. I'll use the stock ones.
Is that upper bolt sticking through your strut rod? If so, that needs to be able to articulate - the strut rod pivots on the upper mount as the control arm goes through its range of motion. Just sayin...
If the movement your talking about it suspension travel, my springs are very stiff. There's little to no movement that low. Also aside from some VERY stiff rubber inside of the stock top hat on a 510. It's mounted exactly the same way. The stock mount has only a single solidly mounted hole that the strut rod bolts too. Unless I'm missing something here I think it's good to go.
the word is "voila" it's french: used to call attention, to express satisfaction or approval, or to suggest an appearance as if by magic
not that you care but i just had to throw that in there.
did you use automotive grade hardware?
& lastly, i ♥ your valve cover.
how does it pivot? the strut has to pivot on there and the stock bearing isnt in there but since your running coil overs the bearing is in the top hat
I'm putting in a bearing, like the ones in the T3 top hats(needle bearing style) or else just the same as the stock bearing in the top hat. It will go between top hat and my home made plates so that the struts can swivel freely when turning.
As the suspension moves, the strut rotates around the strut top. The LCA straightens out and pushes the bottom of the strut away from the car, and vice versa. In a stock top hat, there's a rubber isolator that absorbs this. On aftermarket camber plates, there's a little spherical bearing and allows this movement. See the middle of the T3 plates here: https://technotoytun...es/DSC_9487.jpg
This movement is different than what the needle bearing is for.
Bolting the strut top hard and fast to the strut tower probably ain't a good idea. Even with stiff springs, the suspension probably moves more than you think. The stiffer springs have increased the frequency, so it moves quite a bit faster, so it may be difficult to see and/or notice. Even if it's only a little bit, it will still fatigue the strut towers.
You can get those little spherical bearings from McMaster Carr I think. Wouldn't be too hard to find the right dimensions (it's either 5/8" ID or 3/4" ID, I forget), but I don't how you could add them to the plates. I don't know how they would respond to having their collars welded to something. Every one I've seen is always an interference fit and/or held in with little c-clips (the T3 plates have both I think). Ideas?
You could also add some rubber to you plates somehow. Find some bushings with the right ID and cut them short. Not as cool as the spherical bearings, but would prevent you from eventually ripping a strut tower top out.
Great work. :thumbup:
Ok, cool good info my friend! I'll ponder my options. Dont want the strut threads snapping
Nice job. One additional consideration would be to move the strut mount rearward slightly to gain a small amount of caster. Of course it may be with a slight tradeoff of increased steering effort.
But with the tires already being to close to the footwell (only made worse by a severely lowered car), wouldn't it be better to add caster by pulling the bottoms forward?
