MOAR LOW
AWSpoofwil
soo i want to lower my 78 KC even more, and i wanna know what the easiest/ cheapest way is. its already lowered on what looks like to be 2-3 inch blocks (dont know for sure havnt measured them) and i suspect its already missing leaf springs (its only got 3 per side on the back axle, 6 total on the truck)
and since i know all yall (myself included) love pics heres the ratsun link to them... http://community.ratsun.net/topic/48224-78-620-king-cab-my-first-datsund/
  • Replies 18
Got mine At The JY For $17
I Flipped A Spring And Added Another Spring From The Original 620 Pack For Moar Stiff
720 (I Think It Is 4X4 Only) Alone Lower The Truck 1.5"
They Also Provide A Smoother Ride (Somewhat Like Cutting Springs)
Whitch Is The Opposite Of What You Want When Lowering
Mixed/Flipped Springs Lowered Mine 5"
You Will Want Shorter Shocks And Knotching The Frame With A Pipe Or Z
Depending On How Much You Want To Lower The Truck
okay thanx. mines already about 2.5- 3inches low, but if i flare out the fenders the slight wheel gap is gonna increase so i would wanna lower it more. so basically if i get the 720 leafs with the 3(ish) inch lowering blocks i already have, it will sit about 4.5-5inches lower than stock? and what do i do the front to lower it?
Turn The Torsion Bar 2 Teeth
Since You Have A 78 You Can Simply Lower The Shock Mounting Pos. 2"
Or You Can Raise The Shock Towers Same Thing Either Way
I Used Diplomat Shocks Which Are Almost 3" Shorter
Low Profile Bumpstops
This Is About 4"
It Can Go 2" More But I Will Need Different Wheels To Turn
Also Get An Alignment Done After This
This Is About 4"
Can you tell us more about the diplomat shocks? These must be for the rear? What year diplomat?
3-4inch blocks in back. $35 at oreillys
remove all leafs accept main leaf and the small overload leaf.
turn down tortion bars all the way... if fronts still a lil high (shouldnt be with 3 inch blocks in back) reindex your tortion bars,
heres a pic of mine done the way i explained. rides good
