Atomic
Datsun B310 turbo coupe, A15 project
This is quite something new to me. So is the air coming in from the valve cover and exiting at the side of the block? (normally vacuum pulled via PCV valve at the intake manifold) ?
Edited by Atomic
Share this post
Link to post
More parts ordered.
More intercooler piping, fully recirculating bypass valve, more vacuum piping and clamps. Also ordered couple more 90 degree AN6 PTFE compatible couplings.
Also sent inquiry regarding some oil catch cans. Was looking some looking like this:
Had a plan to pull a vacuum from before turbo compressor and insert one way valves to the system. Two catch cans, one for crankcase ventilation and other one for valve cover?
Share this post
Link to post
Under part throttle when intake vacuum is present the PCV draws fresh air into the valve cover from the air filter and through the crankcase and out the vent. At heavy throttle when vacuum may be lower AND there may be too much blow-by from the rings the crankcase vapors back up and push out the valve cover hose, into the inside of the air filter and the carb sucks them in and they are burned. With a turbo it might just be easier to run the valve cover hose to a catch can.
Share this post
Link to post
Should i just run valve cover hose and crank case hose to two separate catch cans? With both under vacuum taken from compressor inlet?
Share this post
Link to post
22 hours ago, datzenmike said:
Too bad there won't be a PCV valve.... Or could you run the block vent to one on the throttle chamber? It would be forced closed under boost (the PCV is a spring loaded valve) and only works under vacuum conditions. I highly recommend that everyone keep their PCVs working as it draws (very small amounts of) fresh air through the engine to displace humidity (water vapor) and combustion blow-by and keeps the oil much cleaner and less contaminated. During boost, any blow-by will come out the calve cover vent... for that use a catch can. You certainly don't want crap in your oil on a turbo.
Above I was suggesting putting a PCV valve on your plenum that all cylinders can draw from. This would work exactly the same a s a carburetor set up. The PCV is a one way valve and will close under boost.
If you just vent the crankcase and the valve cover, separately or together, there is no fresh air flowing through the engine.  What ever fumes and moisture produced in the engine when you shut it off will just condense and mix with the oil.
Share this post
Link to post
But that wouldn't work under boost? So wouldn't taking PCV from compressor inlet be better?
Share this post
Link to post
It needs a vacuum source, a strong one like the intake. On a carburetor engine at full throttle there is pretty much no PCV because the intake vacuum is almost zero anyway.
The compressor inlet is extremely weak vacuum because one end is open to atmospheric.  Also fumes would get all over the turbine blades. The valves are washed clean by the injector spray.
Share this post
Link to post
I will probably then have to use two can system, like presented here:
works under boost and engine vacuum
Share this post
Link to post
Imagine a PCV  valve set into the intake side where all the intake pipes can use it. Connect to the block vent. Somewhat like the system on the right but without the can. Engine runs exactly like it would with a carburetor when not boosting. Valve cover hose goes to a single catch can for boost only operation. Simpler, less parts, less hoses and just as effective.
Number #2 above marked OEM can't be right. Valve cover fumes directed into the inter cooler??? I don't think so. The inter cooler would clog eventually.
Share this post
Link to post
Wouldn't that draw oil into intake plenum when not boosted? I don't mind putting more stuff into the engine bay to keep the blowby mist from circulating back to cylinders ?
Edit: i just want the ultimate system ?
Edited by Atomic
Share this post
Link to post
At part throttle there won't be much oil mist created in the crank case and the engine will be basically operating as a stock engine would.... and the block vent is heavily baffled and screened before the PCV valve. The PCV valve is a small hole blocked by a ball bearing held closed by a spring. Intake vacuum opens it against the spring so before there is boost pressure the PCV is closed. Anything and everything has to exit the valve cover hose.
Share this post
Link to post
Mmm... I like your reasoning but I still want to build the double one ? I can always go back and check how much the second can really did for me and delete it if it aint worth the hazzle.
Share this post
Link to post
Still waiting for some new parts, doodled with some paper and cardboard to see what I could do on the backside of turbo coupe:
img_20190309_154828_by_atomicsickness_dd
img_20190309_154913_by_atomicsickness_dd
img_20190309_155021_by_atomicsickness_ddimg_20190309_155014_by_atomicsickness_dd
I think it could be fun to try a rear diffuser also with this build? Something that I can never the less take off if it doesn't seem to fit the build.
img_20190309_155214_by_atomicsickness_dd
Maybe not as agressive as first doodled but anyways.
I took the gas tank to its place and need to drill the holes for the fuel pump assy and finish out the fuel lines. Still waiting for some connectors to arrive.
img_20190309_155408_by_atomicsickness_dd
Share this post
Link to post
I just realized that only few more steps for engine start:
Plenum ends need to be blocked
IAC valve for the setup
Cold side intercooler piping
Intake manifold needs a bit of polishing and patching
Routing a throttle cable
O2 sensor to the downpipe
Turbo water inlet fittings
Dangerously close! 😄 I need a bit more money to buy the necessary stuff. Possibility to start in next month?!
Edited by Atomic
Share this post
Link to post
Got the hot side of intercool piping done:
img_20190315_114529_by_atomicsickness_dd
Bought a GFB D+ by-pass valve to do the job:
img_20190315_114607_by_atomicsickness_dd
img_20190315_115733_by_atomicsickness_dd
Got a bunch of new fittings too. Will be drilling the tank today and hopefully finishing the fuel line system all in all
Share this post
Link to post
Got the retrofit kit fuel pump mocked and all the fuel lines are now done:
img_20190315_184013_by_atomicsickness_dd
I should probably be drilling another hole next to the fuel pump assembly for future fuel level sender assembly. Also the tank needs new breather hoses so I'll be welding some AN4 plugs to it.
I will check if I have any suitable sheet metal for the rear light panels. If I do, I will do cutouts for the new rear lights. Otherwise I will probably continue by grinding the plenum and making the endcaps for it.
Share this post
Link to post
Took the wiring harness off from the old lamp assembly. Oddly enough the bulb sockets screwed on quite happily, so I was able to have visual stimulation:
img_20190315_195641_by_atomicsickness_dd
img_20190315_200341_by_atomicsickness_dd
img_20190315_200427_by_atomicsickness_dd
img_20190315_200312_by_atomicsickness_dd
Tried also the chrome bumper on:
img_20190315_203212_by_atomicsickness_dd
But it was for some reason too far away from the body, the sides gave it away too much. So I decided to take a look how the supports are holding up and this came up:
img_20190315_211024_by_atomicsickness_dd
img_20190315_211033_by_atomicsickness_dd
img_20190315_211053_by_atomicsickness_dd
I also managed to drill out the end caps for the plenum, was left wondering where I had the intake manifold brake booster fitting. I'm able to get sheet metal for next weekend for the tail light panels. Will continue more tomorrow \o/
Share this post
Link to post
Blocked the throttle body IAC opening by inserting a silicone hose into the front hole and used a self tapping screw to seal it completely:
img_20190316_114212_by_atomicsickness_dd
img_20190316_114254_by_atomicsickness_dd
img_20190316_114328_by_atomicsickness_dd
I left the other path open because then I'll be able to use 2-pin IAC from volvo 740 for example and make flanged fitting that will bolt into the IAC surface on the throttle body. The only IAC modules that were available were 4 pins ones, and I'm only able to control a 2 pin one, too bad i guess. But modifications are not anything new in this thread.
Speaking of modifications, the tail light swap took another step, I had such a large grin on my face when I put the lamp into position 😄
img_20190316_144549_by_atomicsickness_dd
img_20190316_145435_by_atomicsickness_dd
img_20190316_185819_by_atomicsickness_dd
I didn't bother to cut out the old frame out to reuse it later if I want to convert back. What holds me back the most in creating something new is the fear that I might make something ugly or non functioning. But this I have to say it came out really nice. The other hole was cut out with a bi-metal circular saw, but i busted it before i could do the other one... So I used my small dremel with a cutting wheel to make the other one, both came out pretty nice. I'm planning to have the rear panel to be black while the rest of the car would be blue (maybe?) 😄
Share this post
Link to post
Looking nice!
Share this post
Link to post
Got the other side on too:
img_20190316_210621_by_atomicsickness_dd
img_20190316_214451_by_atomicsickness_dd
img_20190316_214511_by_atomicsickness_dd
img_20190316_215138_by_atomicsickness_dd
That's hot!
tenor.gif?itemid=13080022
Share this post
Link to post
Dude... That came out even more awesome than I thought it would...  👍
  • Thanks 3
Share this post
Link to post
I wish I had posted that.
  • Haha 1
Share this post
Link to post
Dang.. does look good!
  • Thanks 1
Share this post
Link to post
Moved the bumper back about 32 mm (quite a lot). Now there is a 10 mm gap between the body and the bumper and it looks so much better than the original imo.
img_20190317_125323_by_atomicsickness_dd
Also no regrets:
img_20190317_113609_by_atomicsickness_dd
Share this post
Link to post
Cleaned off the rust from the tank surface
img_20190323_125037_by_atomicsickness_ddimg_20190323_133126_by_atomicsickness_dd
and then painted it with hammer paint with gloss black finish:
img_20190323_141242_by_atomicsickness_ddimg_20190323_164229_by_atomicsickness_dd
Also bought AN3 fittings for the clutch lines. I need to buy few more fittings to finish out the plenum. Also I have been looking for devcon epoxy steel putty for sealing the intakemanifold off. Seems pretty expensive, but also pretty good stuff for high temperature and has chemical resistance.
Edited by Atomic
Share this post
Link to post
