Atomic Posted December 27, 2018 Author Report Share Posted December 27, 2018 Got the brake caliper ready: Tidied up some brakelines.. The enginebay is still a mess since I haven't decided how to route some of the cables yet: I need to make some supports for the brakelines at the ends still, but both front lines are hooked up: Decided to cut up the old welds that I did back in the 2012 and started making the rear wheel arch: Quote Link to comment
Atomic Posted December 28, 2018 Author Report Share Posted December 28, 2018 Did a quick check with wheel clearance and everything seems to be fine: Got almost all of the pieces welded in, i was able to tuck the fender lip nicely inwards also: 1 Quote Link to comment
Atomic Posted December 28, 2018 Author Report Share Posted December 28, 2018 Got a package: A new turbo blanket, can withstand up to 1100 C. Also, note to self, never touch the turbo blanket with bare hands, got a bunch of small needle like stuff in my hands and they hurt ? Manifold wrap (15m) + stainless steel zipties : And more stainless steel V-flanges: And started welding the other side: Quote Link to comment
Atomic Posted December 29, 2018 Author Report Share Posted December 29, 2018 Got both sides ready: 1 Quote Link to comment
Atomic Posted December 30, 2018 Author Report Share Posted December 30, 2018 Took around 30 hours to do all the welds for both sides all in all~ 1 Quote Link to comment
Atomic Posted December 31, 2018 Author Report Share Posted December 31, 2018 Digging up some old pictures of before and after: Hmmmm ? 4 Quote Link to comment
Atomic Posted December 31, 2018 Author Report Share Posted December 31, 2018 I'm guessing I will also go with quad tail lights that I just bought from auction: Quote Link to comment
Atomic Posted January 1, 2019 Author Report Share Posted January 1, 2019 Cleaned up the garage from all the scrap pieces laying on the floor and vacuumed all the metal and dust: Also welded the last major remaining spot on the car: And painted the other rear brake caliper: Quote Link to comment
Atomic Posted January 2, 2019 Author Report Share Posted January 2, 2019 (edited) Does anyone have an idea where to get in tank fuel pump modules without the fuel pump? I would want to retrofit one to my old tank, with a reasonable price around 100-200 USD Edited January 2, 2019 by Atomic Quote Link to comment
dukerollo Posted January 2, 2019 Report Share Posted January 2, 2019 I’m interested to see how you do the taillights. I have some ideas kicking around, but I’m not sure they would be worth the effort. Quote Link to comment
Atomic Posted January 2, 2019 Author Report Share Posted January 2, 2019 Just now, dukerollo said: I’m interested to see how you do the taillights. I have some ideas kicking around, but I’m not sure they would be worth the effort. Yeah, It has couple of issues right of the bat, such as legal matters here in Finland. So we'll have to see how it goes once they arrive ? Quote Link to comment
Atomic Posted January 3, 2019 Author Report Share Posted January 3, 2019 Inserted fuel pressure regulator to the fire plate with aluminium rivets: Quote Link to comment
Atomic Posted January 3, 2019 Author Report Share Posted January 3, 2019 Bought rear shocks for the datsun, they're double adjustable and originally for ford mustang: Also bought a retrofit kit for the fuel tank with E85 capability: Also also, sent the chopped rear springs for a local shop so that they will make a modified ones that are around 3kg/mm in stiffness. I have 4kg/mm on the front currently with coil overs. Lot of $$$$ burned, rip me.. 1 Quote Link to comment
Atomic Posted January 7, 2019 Author Report Share Posted January 7, 2019 (edited) Item Price (USD) Price (EUR) Bosch Injectors 315cc 4x 133.02 Fuel pump emblem 13.56 Front suspension bush kit 59.99 Engine mount pair 39.99 Front windshield seal 39.99 GX double valve spring kit 135 GX double valve spring seats 55 ARP head stud kit 107 VOLVO 850 2.3 T5 R turbo 465.57 Turbo manifold flanges 258.74 Exhaust manifold stainless pipes 183.63 Opel Vectra Gas shock absorbs 111.29 Engire repair kit (seals, bearings..) 278.22 Cam bearings assembly 194.75 Piston&bearing coatings 83.47 Coilover springs (front) 83.47 Front fender (passanger side) 69.56 Rocker Panels 55.64 Throttle body (50mm) with tps 83.47 Mazda 626 Cooled brakes 2x 35.95 Original gauges 5 Volvo 240 4-piston calipers x2 128 Volvo 740 brake discs x2 40 Bosch EV1 injector connectors 8 GM airtemp sensor (open) 26.1 GM air/water temp sensor (closed) 21.6 VR-sensor 14.4 Ignition coil Bosch 4 cylinder 103.55 Innovate LC-2 wideband lambda 197.1 Triggerwheel 36-1 15.2 ATEcu V2 controller 250.2 ATEcu V2 wiringharness 117.3 Flywheel balancing and machining 150 Transmission axle machining 50 Sandblasting parts 20 Mishimoto intercooler 150 Aeroflow pump (E85 compatible) 500hp 80 Intercooler silicone piping (2.5inch) 75 Golf I flares x4 96 Track rods x2 24 Track rod rubbers 5 Wheel spacers x2 50 885 15'' Rims x4 436 Front tires x2 120 Bumpsteer spacers x2 90 Rear axle dust plate 12 Handbrake clamps 5 Full lock kit 59.77 Original dash lid 40 Turbo oil feed line kit 16.96 Turbo water coolant line kit 23.75 Turbo oil drain return pipe 9.74 Aluminium rod bar (for injectors) 5.61 Fuel injector railing 20 Lower ball joints x2 20 ARP connecting rod bolt kit 80 Dashboard cluster 60 Shortening and balancing the drive axle 160 Forged connection rods 215.17 Boost solenoid 37.91 GT-R badges (2pcs) 11.13 Nismo badges (2pcs) 11.13 3'' V-band clamps (3pcs) 26.77 Oil pump 55.33 Door hinges 200 Front fender protector (RH/LH) 34.18 Wilwood pull type clutch slave 80.06 Camaro Z28 tail lights 65.73 Stainless steel 304 NPT fittings (2pcs) 3.16 VIN number plate 7 Golf Mk II angel eyes headlight kit 85 Autogauge oilpressure gauge 90 Autogauge RPM gauge 100 Autogauge Speedometer 80 Autogauge boost gauge 85 Autogauge water temperature gauge 75 Brakepads for front 12.9 Castrol rear end oil 75W-90 (2l) 37.8 Red line Race ATF type F (~3l) 52.29 Rear brake calipers Volvo 740 149.8 Brakeline parts (T-flanges and fittings) 23.6 Brake pads for rear 11.9 Brake pad installation kit 4.9 Aluminium piping for intake manifold 153.83 Silicone hosing for intake manifold (4pcs) 112.2 Intercooling silicone hosing 31.53 Aluminium piping for intake manifold 68.85 Aluminium injector pocket (weldable 4pcs) 24 Clutch master cylinder 18.9 Brake master cylinder 68 Hood ornament (2pcs) 10 Stainless steel 3'' exhaust tubing 250 Stainless steel 3'' muffler magnaflow 50 Ford mustang adjustable rear shocks (2pcs) 520 Retrofit fuel tank assembly with fuel pump (E85) 219 Turbo blanket T4 70 Titanium exhaust 'tape' 10m 34.9 Custom rear springs (2ps) 300 Spark plug leads 39.9 Aluminium piping for intake manifold 50 Brake hardlines 25m 79.9 2.5mm wiring 10m 7.9 Velcro cable ties 4.9 Water fittings for turbo feed 27.2 Original dashboard (used) 60 Front bumper holders (early model) 15 Subtotal so far = 3642.08 5402.28 roughly 9k EUR spent. No postage costs calculated, some parts still missing Edited January 7, 2019 by Atomic Quote Link to comment
Mattndew76 Posted January 8, 2019 Report Share Posted January 8, 2019 It Adds up without us being fully aware until the "List" I haven't stopped to add up what I have spent, and almost don't want to quantify it because the wife might give me grief about it. Might or might not she is usually reasonable about my auto spending. Car is looking better by the day btw. 1 Quote Link to comment
datzenmike Posted January 8, 2019 Report Share Posted January 8, 2019 Same here making an R1 intake. More was spent finding what wouldn't work. 2 Quote Link to comment
Atomic Posted January 10, 2019 Author Report Share Posted January 10, 2019 Hmmmmm I think I'm in love 2 Quote Link to comment
Atomic Posted January 12, 2019 Author Report Share Posted January 12, 2019 Finally got the 3/8 NPT tap and was able to get the temp sensor to the cylinder head: I had some issues with the front fenders and I thought I did a poor job on them so I ended up cutting a piece from it and streighten them both sides: Took some photos around the car with doors on: I hope that my new rear springs and shocks will arrive 'soon' 1 Quote Link to comment
Atomic Posted January 14, 2019 Author Report Share Posted January 14, 2019 (edited) Oh well, Jegs informed that the ETA for shipping is in March... Have to wait for the shocks and the retrofit kit.. But I'm ordering a new bottle of argon again. Refilling in Finland costs 111 EUR, buying one new from europe with shipping inc. around 109 EUR... and it will even ship faster. Update: Hmm, Jegs updated that the parts will ship in 24 hours now.. What?! Quite a difference in few hours, just after i had originally posted this, they tried to sell me another one for extra +200 USD model, but I refused. Seems odd.. Edited January 14, 2019 by Atomic Story update Quote Link to comment
Atomic Posted January 19, 2019 Author Report Share Posted January 19, 2019 Got a new plate to stance some numbers: Welded some M10 nuts into some stuck and broken bolts. Now I should be able to mount the fuel tank to the rear atleast. I have been keeping my eye on a fuel tank kit that suits E85, will need to get more money before I can buy more stuff Tapped the fuel rail for 3/8 NPT, will buy a 3/8 NPT to 8 AN fitting, and then shrink it down to 6 AN and have routing to fuel pressure regulator and to the fuel tank And then mocked up the front fenders again: Then started dealing with the chrome bumper, I drew some new markings for the new mounting holes inside of the engine bay: Quote Link to comment
Atomic Posted January 22, 2019 Author Report Share Posted January 22, 2019 (edited) Should be able to get the welding gas next week. The shipment from Jegs ETA is 28.1 and should probably get the new rear springs soon too. When I get the welding gas the starting of the engine starts to creep closer and closer. Also toying around with an idea of having the car color with pearl blue: Edited January 22, 2019 by Atomic Quote Link to comment
datsunfreak Posted January 22, 2019 Report Share Posted January 22, 2019 I like these lights a lot more than I thought I would... What about a clear piece of plastic to cover the hole with those mounted on the inside? Quote Link to comment
Atomic Posted January 22, 2019 Author Report Share Posted January 22, 2019 31 minutes ago, datsunfreak said: I like these lights a lot more than I thought I would... What about a clear piece of plastic to cover the hole with those mounted on the inside? Depends, not sure if they will qualify the lights if they're behind the original frames (regarding legal matters, registration etc). I kind of like how they look inside of the original holes too. Quote Link to comment
Atomic Posted January 25, 2019 Author Report Share Posted January 25, 2019 Got more argon \o/ Bought 10l bottle as mentioned. Got 220 bars of pressure, should give me enough gas to weld the plenum and rest of the exhaust system. Quote Link to comment
Atomic Posted January 25, 2019 Author Report Share Posted January 25, 2019 Started welding some aluminium piping for the plenum. Took some time again to get used to aluminium welding the 45 degree pipes were salvaged from previous manifold trial Quote Link to comment
