1967 520 gasser
520 gasser
I just startted this truck about a month ago I will try to get so pic on here this coming week.
This little truck had a lot rust the past two weeks I cut both rockers out and the hole floor except for the back half of the tunnel. Had to build new body mount and in the process I added a 1 3/4 round tribe inside the new rockers I built to tie the front and rear body mounts together and to give me a place to mount the roll cage to
Motor is a 400 small block Chevy
All new frame
Straight Alex for the front
Have 9 inch ford for the rear
15x10 smoothie with 29x9 cheater slicks
  • Replies 139
  • 1 month later...
Every one has said the same thing about the 400 they are no different than a 350 other than there is no water flowing between the cylinders and it is externally balanced. I have read many books and talked to many motor builders and they get a bad rep because people put 350 heads on without drilling the steam holes in the head witch builds psi in the block and creaking the. Block
