josh817 Posted November 10, 2012 Report Share Posted November 10, 2012 I have a lot of shit stacked up that I need to clear out. I'm going to name off some prices but its all OBO. I am in Keller/Arlington Texas 76248. I will post more stuff as I get more time. Probably around Thanksgiving, and then again after the second week of December when I get back home. Z flywheel, I measured it to be 225mm $25 L engine water pump and clutch $15 521 door panels $15 for both. One will need to be rewrapped. Board looks good, some of the tabs have pulled out Z visers. Not torn, real good condition $20 521 Cab Light. I never bothered to check to see if it worked. The on/off switch moves freely, and the bits inside move as they should. $5 I don't have a price for this next stuff. PM me for inquries. 280ZX rear disc brake conversion for Z's. I don't know if they work on 510's. I have used SS lines, the old used pads, a set of new pads, all the hardware, two rebuild kits, aluminum anodized brackets, calipers and hats, and two new rotors. I was preparing to put them on my 240 and I changed my mind. I want to stay with drum brakes. To get rid of this setup, I am willing to do a trade. New/lightly used drums, shoes, and wheel cylinders. I don't want old leaky stuff, or drums that need to be turned. If you want to buy instead of trade, then again, PM me and we can talk. Realize that my asking price will reflect what I am expecting to pay to redo my drums. I disaassembled everything, cleaned them thoroghly, painted the hats, just have to be put back together. For those of you that are worried about having to remove the hub to get the bracket on, I have the ability cut one of the holes/corners off the brackets, so that you have a 3 bolt bracket that can bolt on without removing the hub. Assorted interior plastic. All from S30's. PM me if you need something in particular and I will ttry to find the best piece. I have plenty more stuff that needs to go. PM me if you have any particular requests. Some stuff I'm saving for myself, other stuff is good to sell, never know. Thanks, Josh 1 Link to comment
josh817 Posted November 11, 2012 Author Report Share Posted November 11, 2012 280z window regulator $20 Z door lock, no key $5 Z arm rests $10 for both Whatever this thing is. Looks like intake ducting or something $5 Badges $10 for both Fuel rail or vacuum rail. I forget if it is from a 240 or a 280 $15 280ZXT fuel rail for barbed injectors $15 280 tail lights, good condition, no cracks $30 280 glove box door $10 Whatever these things are from a 280z. Looks like a vacuum... thing, and some sort of piper. $5 takes them both Turbo oil lines $10 Ballast resistor $5 Turbo oil pan, has a ding in the sump but nothing major $25 240 choke cable assembly No choke knob to it but it does have the electric switch for the warning light $30 521 washer motor $5 Remember everything is OBO. Make an offer if you want. Don't forget to consider the brake trade. I really need to repair my drums, lets help each other out! Thanks, Josh Link to comment
olderdat620 Posted November 13, 2012 Report Share Posted November 13, 2012 Hello the L series water pump with clutch to 92281 and woud u accept a postal money order? Link to comment
josh817 Posted November 13, 2012 Author Report Share Posted November 13, 2012 Sure I can do that. I will PMyou with a shipping quote. Link to comment
DanielC Posted November 13, 2012 Report Share Posted November 13, 2012 How much for all the 521 bits and pieces, to 97068. Here is a picture of one of my 521 trucks. It looks better than that, now, but the red door panels would fit, and are the color it came from the factory with Here is a more current picture. Link to comment
josh817 Posted November 14, 2012 Author Report Share Posted November 14, 2012 Daniel can you wait until the weekend? All that stuff is at my mothers place. I will have to find a box. The only 521 things I see that I have posted were the door panels, washer motor, and water pump. Pump is spoken for unless he backs out. I can throw the washed motor into the door panel box easily. Atleast your bench is looking good! Link to comment
DanielC Posted November 14, 2012 Report Share Posted November 14, 2012 This is my project thread. It was started April 9, 2011. http://community.ratsun.net/topic/30606-my-ratsun-datsun-521/ I can wait four more days. Thanks Link to comment
