510 SEDAN - 82-83 280zx rear disc adapters. Run #2
I have 3sets of brackets and 1 set of scratch and dent brackets.
Original thread with more info: http://community.ratsun.net/topic/47712-510-sedan-82-83-280zx-rear-disc-adapters/
They will be anodized clear and come with hardware. I designed the cable adapters to utilize Lokar's universal Ebrake cables so I can route my cables properly http://www.lokar.com...ake-cables.html
I'm asking $175/set + shipping for Brackets alone.
If you want the Lokar Adapter kit it will be $75/set + Shipping.
I built the Lokar kit to use this cable set.
http://www.summitrac...-80FU/?rtype=10
You can use this handle or adapt any handle you want:
http://www.summitrac.../LOK-EHB-7000F/
I run PowerSlot Rotors. http://www.powerslot.com/
Street Performance Brake Pads from http://motorsportauto.com/
Brackets with Lokar Kit:
Brackets only:
dodgydan
Just Lokar Kit:
Cable Adapters
Finished Product:
  • Replies 14
I've had questions about using the stock ebrake handle and cables. This along with the 280zx handle and cable. These will both work with the Lokar Cable kit. You just have to route the cables correctly and use the Lokar mounts and attachment points.
Here's the end of the stock ebrake cable with the Lokar cable attachment slid over it. The threaded hole in the Lokar piece is larger then the stock end. Just slip it through and use the stock jam nut.
I have 1 set of scratch and dents. Really just had a couple parts shift during the chamfering op. This affected only one side per set. I now have 1 set for sale like this.
Price is $150 Shipped for the scratch and dents, just brackets and hardware:
Here's the newest batch:
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
