Cracked block - What to do ?
dotdat
Working on restoring my 1974 Datsun 620. I pulled the oil drain plug and about a pint of anti-freeze coolant ran out followed by some nasty, brown colored oil.
Next step: I blocked off the lower block return, then pulled out the thermostat and filled the opening with about a gallon of 50/50 anti-freeze.
There now is a very slow dripping of anti-freeze comming out of the oil drain. It appears that it has a cracked block. The truck was parked outside for several years and I would guess it contained coolant not mixed strong enough for our cold winters. The freeze plugs seem to be intact.
Question: What the hell do I do now?? Any repair possible? Or is it toast. Your comments please.
  • Replies 10
Or leave the pan on. Listen with a hose while pressuring the system.
Is air leaking sounding loudest?
* Through oil fill hole? If not, no need to pull the oil pan.
* Through carburetor? Leak is perhaps in intake manifold, intake gasket or cylinder head
* Through exhaust pipe? Leak is perhaps in exhaust gasket or cylinder head
