Dguy210 Posted November 5, 2012 Report Share Posted November 5, 2012 So I'm thinking of doing a KA swap into the B210, but I would like to skip the whole cutting and reversing the crossmember business for the midsump B210. From the Datsun1200 tech wiki it looks like a front sump KA should go into a 1200 without flipping the crossmember (maybe just some notching?). I know a B210 crossmember won't work for a B110, but will a B110 crossmember bolt into a B210? Anybody know or try this? Quote Link to comment
Ranman72 Posted November 5, 2012 Report Share Posted November 5, 2012 hm new question I thought you were talking about the trans crossmember Quote Link to comment
ggzilla Posted November 5, 2012 Report Share Posted November 5, 2012 I don't think it will work unless you changed the LCAs and struts to the smaller type. Maybe trade with some Aussie? They probably like to get the North America B210 mid-sump crossmember. All they got was the front sump crossmember. Quote Link to comment
ggzilla Posted November 5, 2012 Report Share Posted November 5, 2012 datsun1200.com says: B110 holes are 656 mm apartB210 is slighty wider Quote Link to comment
Dguy210 Posted November 5, 2012 Author Report Share Posted November 5, 2012 I don't think it will work unless you changed the LCAs and struts to the smaller type. Maybe trade with some Aussie? They probably like to get the North America B210 mid-sump crossmember. All they got was the front sump crossmember. Would that even fit? I thought the non-north america suspension for the B210 was very different as the N/A market used the 610/510 style suspension. datsun1200.com says: Hmmm... ok that doesn't look like it will work. Damn, I was hoping they were closer, I've swapped out the tierods/center link/idler arm from a B210 to a 1200 with no problem so I thought the LCA's would be more similar. Doesn't look like it, bummer. Guess I will look for either a B210 crossmember or a 510/610 (I believe this fits) one to cutup so the car doesn't go down. Quote Link to comment
ggzilla Posted November 5, 2012 Report Share Posted November 5, 2012 B210 everywhere else used B110/B310 style LCAs etc. So it would be easy to swap the crossmember (NA for non-NA), just use the B110 or B310 parts as necessary. Only the B210 with L-series engine used 510-style suspension. And for some weird reason they used that in all NA B210s, along with the weird mid-sump oil pan (the one that causes all the KA swap problems). Maybe it was a rush decision to get the A13/A14 into production just for USA. It doesn't seem to make any sense, but they did it. Quote Link to comment
