jesusno2 Posted March 29, 2016 Author Report Share Posted March 29, 2016 Thanks man Quote Link to comment
]2eDeYe Posted March 29, 2016 Report Share Posted March 29, 2016 This is probably my favorite build currently. :cool: 2 Quote Link to comment
Draker Posted March 30, 2016 Report Share Posted March 30, 2016 Agreed! High quality stuff in this thread! 1 Quote Link to comment
Eagle_Adam Posted April 11, 2016 Report Share Posted April 11, 2016 This happens every time..... Every damn time!! They finally get their hands on the LSD and they disappear -.- 2 Quote Link to comment
angliagt Posted April 11, 2016 Report Share Posted April 11, 2016 Probably working a lot to pay for this build. 1 Quote Link to comment
jesusno2 Posted April 12, 2016 Author Report Share Posted April 12, 2016 Yea that^^^ nothing to share of substance really got my ebrake cables all finished and working with the stock 210 handle and stuff working on the battery in the trunk deal. I did get a muffler finally waiting a on cheap resonater i bought as well alot of nickel and dime stuff then wiring and fuel system 1 Quote Link to comment
jesusno2 Posted April 15, 2016 Author Report Share Posted April 15, 2016 Mail man came today resonator dug this one cause of the 02 bung built in and it was super cheap! And some kinda saftey device in my death trap of a car if you have a battery in a truck its a good idea to have some way of disconnecting it just in case so i bought this circuit breaker. 1 Quote Link to comment
Sierra Posted April 15, 2016 Report Share Posted April 15, 2016 This thing is going to be a beasts when is done. Keep it up man. Great built! 1 Quote Link to comment
]2eDeYe Posted April 15, 2016 Report Share Posted April 15, 2016 I think I need a couple of those breakers :cool: 1 Quote Link to comment
jesusno2 Posted April 16, 2016 Author Report Share Posted April 16, 2016 Yea man its cheap insurance so your expensive build doesn't have a stage 5 melter on the side of the road somewhere cause your + battery cable shorted out somewhere under the car 1 Quote Link to comment
jesusno2 Posted April 17, 2016 Author Report Share Posted April 17, 2016 3rd member finished LSD carrier setup beautiful just like it was factory 3 Quote Link to comment
COOCHaDAMus Posted April 17, 2016 Report Share Posted April 17, 2016 is this lsd out of a 200sx. i hope so local scrapyard has one. Quote Link to comment
jesusno2 Posted April 17, 2016 Author Report Share Posted April 17, 2016 Toyota man Quote Link to comment
jesusno2 Posted April 24, 2016 Author Report Share Posted April 24, 2016 So doing a little work in the trunk area today,, running my main battery cable, and tidying up. Still need to build a battery hold down etc. So have a bit of OCD when it comes to fasteners, i hate seeing crusty one's, and those god awfull sheetmetal screw's that are always stripped out. So when ever i can i use my nut rivet tool so i can use nice new fastners. One of the most handy tool's i have ever bought. These particular ones are 5mm. Used em to mount my power block and circuit breaker. 2 Quote Link to comment
jesusno2 Posted May 1, 2016 Author Report Share Posted May 1, 2016 Tubing straightner i made up 6 Quote Link to comment
jesusno2 Posted May 13, 2016 Author Report Share Posted May 13, 2016 Fuel pump showed up if anyone wants a good cheap inline EFI pump that is OEM quiet these pumps are awesome use them on every efi swap i have done. TREperfomance.com universial 255lph 3 Quote Link to comment
jesusno2 Posted May 22, 2016 Author Report Share Posted May 22, 2016 POR 15 on the rear diff all finished welded and my LSD and 4.10 third installed 3 Quote Link to comment
jesusno2 Posted May 30, 2016 Author Report Share Posted May 30, 2016 Well it made it outta the gargae on 4 wheels and it has functioning brakes and a E brake! 5 Quote Link to comment
Eagle_Adam Posted May 30, 2016 Report Share Posted May 30, 2016 Soooo close!!! What's left? Quote Link to comment
jesusno2 Posted May 30, 2016 Author Report Share Posted May 30, 2016 Fuel system,wiring, the rest of the exhaust (trying to get 3" over the axle is tricky) a driveshaft, and tuning. Quote Link to comment
datsunfreak Posted May 30, 2016 Report Share Posted May 30, 2016 Fuel system,wiring, the rest of the exhaust (trying to get 3" over the axle is tricky) Lower the back 1" then go under the axle? B) 1 Quote Link to comment
Lockleaf Posted May 30, 2016 Report Share Posted May 30, 2016 What about running oval tubing through the tight area? Quote Link to comment
DISLEXICDIME Posted May 30, 2016 Report Share Posted May 30, 2016 Can you run 2 13/4? Quote Link to comment
Draker Posted May 30, 2016 Report Share Posted May 30, 2016 Can you run 2 13/4? Gonna be tough to get that over the axel too. Quote Link to comment
B210ratsun Posted May 30, 2016 Report Share Posted May 30, 2016 Run it out the side, there is nothing that says the exhaust has to run out the back. 1 Quote Link to comment
