jesusno2
KA24DET B310 BUILD UP
picked up this little racer last night runs like a little sewing machine.
Share this post
Link to post
I love 2dr sedan 210s. If only I didnt have to smog them where I live.
Share this post
Link to post
Even got a Ooga horn lol :cool: that's really clean looking!
Share this post
Link to post
That thing is in great shape.
Score!
It will be interesting to see what YOU do with it.
Share this post
Link to post
Yea the horn is awesome! I would like to swap to a CA or KA just wait till i can get a decent deal on one or do some trading for a set. would like to find some enkei meshies for it and do some chassis improvements.
Share this post
Link to post
need some wheels for it. 13 or 14 inch im doing some research on wheel fitment
Share this post
Link to post
Offset numbers mainly. i heard a koing 14x7 -9 works well
Share this post
Link to post
On a B210, yes. On a 210, not so much. Should just barely tuck in the rear with rolled fender lips, but it's gonna stick out in the front a good bit.
If you swap to 280ZX front struts/brakes and add camber plates to run 1-2 degrees negative, you could maybe just tuck the Rewinds.
For a 7" wheel, +0 to +10 works best on the rear, +10 to +20 works best on the front. With the 280ZX strut swap, then the fitment is same front to rear (narrows front track slightly).
Share this post
Link to post
Forum member Lonestar has 15x7 +0 Rewinds on his car. Notice how the rears are 5mm inside the fender but the fronts are 5mm outside the fender?
Swapping to 280ZX struts up front would tuck them in better.
Share this post
Link to post
One of my old cars, 13x6 +0, rears tucked in, fronts flush
Another old one of mine, 14x6 +11, fronts tucked slightly, rears tucked a lot...
Share this post
Link to post
so i took a coil and a half out of both frt and back cant even tell! the suspension needs a serious overhaul
Share this post
Link to post
So really the rear needs spacers to make them look equal ... or different offset front & rear
Share this post
Link to post
Or 280ZX struts swapped in. B)
FYI, this is a +15 front +0 rear:
Share this post
Link to post
I'm to lazy to search! the time will come when i'm ready for now i'm all about getting a powertrain put together.
Share this post
Link to post
got some 92's for my 210 i started the paint stripping process already is why they look so terrible. i'm gonna paint them all back to the og gold. I kinda got stroked though cause one wheel is a different damn offset. the pics were taken with the 0 offset which when you measure them if my math is correct they come out to a -13
poke in the rear  FTW! (ha ha ha ha ha yea im a child)
poke in the front (ha ha ha ha still a child)
I need one more 15x7 with that 0 or 4 inch backspacing.
can't post pics for some reason???
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
