drjeffreys Posted November 1, 2012 Report Share Posted November 1, 2012 EDIT: Just found my answer.. http://community.ratsun.net/topic/38916-proportioning-on-510-with-zx-frot-brake-and-240sx-rear/ Hey. Recently did zx brakes up front, plan on doing the maxima disc or similar in the rear. Currently looking into getting a 79 zx Brake master and was wondering if i should keep the stock 510 "Proportioning Valve". I have heard here and there that it is simply just a splitter. Should i be using something different? or an aftermarket prop valve? thoughts? thanks. Quote Link to comment
Amerikilla Posted November 1, 2012 Report Share Posted November 1, 2012 the ZX master cylinders are internally proportioned so the factory 510 valve is unnecessary. Quote Link to comment
drjeffreys Posted November 1, 2012 Author Report Share Posted November 1, 2012 I understand they are already proportioned, but the bmc only has a nipple for front and rear, no? so a splitter is still needed, which i have been lead to believe is all that the 510s "Prop valve" actually is.. Anyways, i guess ill plumb it up again and hopefully have no bias issues. thanks Quote Link to comment
Amerikilla Posted November 1, 2012 Report Share Posted November 1, 2012 I understand they are already proportioned, but the bmc only has a nipple for front and rear, no? so a splitter is still needed, true. you do need to split them. which i have been lead to believe is all that the 510s "Prop valve" actually is.. Anyways, i guess ill plumb it up again and hopefully have no bias issues. false. with an internally proportioned BMC the bias is pre-set with a "break point" front to back. you would only need to split those 2 circuits from side to side. Quote Link to comment
