bigman420 Posted October 30, 2012 Report Share Posted October 30, 2012 What will i need to switch from column shift to floor shift on my 64? Quote Link to comment
ggzilla Posted October 31, 2012 Report Share Posted October 31, 2012 4-speed FS version FS tunnel cover shifter boot You don't need to remove the column shift. Have fun. Quote Link to comment
wayno Posted October 31, 2012 Report Share Posted October 31, 2012 I could be wrong, but I beleave your also going to need to make a transmission mount, as the column shift trans. mounts differant as I recall. The E1 engine/column shift transmission mount at 4 differant points, two engine mounts, two tranny mounts, floor shift models usually have 3 mount points, two engine mounts, one tranny mount in the center. Quote Link to comment
datzenmike Posted October 31, 2012 Report Share Posted October 31, 2012 Column shift Two mounts at back? Floor shift (I think this is an early 520) anyone know for sure? . Quote Link to comment
bigman420 Posted October 31, 2012 Author Report Share Posted October 31, 2012 I have to change tranny?i can't use different linkage or anything? Quote Link to comment
bigman420 Posted October 31, 2012 Author Report Share Posted October 31, 2012 Can anyone tell me the part number for the rear seal on tranny on my column shift? It is the tranny from top picture that was posted Quote Link to comment
datzenmike Posted October 31, 2012 Report Share Posted October 31, 2012 It should be the same as any Nissan 4 or 5 speed through the 70s, 80s & 90s, well except the 280zx and 300zx turbo. I can get the number this afternoon. Quote Link to comment
bigman420 Posted October 31, 2012 Author Report Share Posted October 31, 2012 Thanx Quote Link to comment
ggzilla Posted October 31, 2012 Report Share Posted October 31, 2012 Sure you can use the old transmission. * Adapt/modify a chevy or ford aftermarket floor shift unit. Haven't heard of anyone doing this. * Or dissassemble it and swap over the different parts from the FS transmission. Top, side cover and internal shift parts. Unknown if they will fit. Part Number Nissan 32136-07200 Seal-oil, rear extension NLA No longer available, but it is a common size: 35x50x11 mm. The 610 seal is same size: 32136-U0100 Quote Link to comment
bigman420 Posted November 3, 2012 Author Report Share Posted November 3, 2012 Thank you for the input......guess I'm stuck with column shift for a while....thank you on part number and measurements Quote Link to comment
