Fender rubber? Insulator? Help
  • Replies 6
Is this between the sheet metal and the fender where the fender mets the body? If so, electricians use a rubber tape, not vinyl, about 1/16 inch or so thick that comes in a roll with usually a red plastic covering to prevent the rubber tape from sticking to itself. I have used this to build up isolating and weatherproofing gaskets between fenders and body joints in the past. I bought it a Home Depot in the [obviously] electrical section. Lay the tape on and peel the plastic protector off. The "other" side has a good cement on it and will stick to sheet metal very well. Good luck!
